is AND broken?
10-11-2015, 01:23 AM
is AND broken?
I have very mysterious problems with the AND function in a program if statement.
The program misbehaves until i remove the AND and use two ifs. E.e IF ((expr1) AND (expr2)) THEN .... fails with bad argument error somewhere in the code. IF (expr1) THEN IF (expr2) THEN ...... make the gremlins go away. Seems odd. I work with android Prime only for now on my Galaxy Tab Pro/Note 2 |
10-11-2015, 05:06 AM
RE: is AND broken?
(10-11-2015 01:23 AM)ji3m Wrote: I have very mysterious problems with the AND function in a program if statement. You can place a DEBUG; statement right before where you think the error occurs and then run the program and this will pull up the debugger so you can see the real cause. Graph 3D | QPI | SolveSys |
10-11-2015, 05:35 AM
(This post was last modified: 10-11-2015 05:35 AM by Didier Lachieze.)
RE: is AND broken?
This has been discussed here.
10-14-2015, 02:09 AM
(This post was last modified: 10-14-2015 02:10 AM by toml_12953.)
RE: is AND broken?
(10-11-2015 01:23 AM)ji3m Wrote: I have very mysterious problems with the AND function in a program if statement. If expr2 has an error in it, the second example works because the IF never gets evaluated if the first IF is false. HPPL, as in most forms of BASIC, evaluates all expressions in an AND statement. There's no early exit if the first part of the AND is false. Example: Code: IF 4<2 AND 1/0 >3 THEN Code:
will work because the 1/0 never gets evaluated. Tom L Cui bono? |
