Solver
10-11-2015, 03:54 PM
Solver
I have wrote a function inside my program. Code:
TEST(x)-0,5=0 Is this posible to do this inside my program? Wich solver do I use? (My function is not linear) Is it also posible to give the error for stopping the solver? Cheers, Jan |
10-12-2015, 05:43 AM
RE: Solver
The following will work. Please note that FNC must be either EXPORTED, or you must fully qualify it in the call to Solve.SOLVE. EXPORT FNC(A) BEGIN return COS(A); END; EXPORT test() BEGIN Solve.SOLVE(FNC(X),X); END; Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
10-12-2015, 07:16 AM
RE: Solver
Cyrille,
Thanks for the response. But I won't to use the solver to search between boundaries. (Like a binary search) Is that posible? Cheers, Jan |
10-12-2015, 03:13 PM
RE: Solver
The solver can be given 1 or 2 guesses to get started, HOWEVER, it does NOT (as a general rule) do a binary search, it uses 3 types of methods: Quadratic, hyperbolic and Newton, basically, it tries first to ascertain what the function looks like and then pick one of the 3 methods to try to zero on the solution. When it feels that it is very close, then it uses dichotomy search. The net result is that there is no guaranties that the zero found (if the function has more than 1) will be close to the provided guesses (although it generally is). Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
10-12-2015, 03:21 PM
RE: Solver
Cyrille
Please can you help me with the syntax. My Function name id SunPos, and I won't found a zero between 5763.9 <= x <= 5764.9. Try to find an example but could notting found! Thanks, Jan |
10-13-2015, 05:18 AM
RE: Solver
hello,
Can you post your program? or at least the function code? Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
10-13-2015, 05:49 AM
RE: Solver
This is my function code; Code:
Thanks for any help. Regards. |
10-14-2015, 05:45 AM
RE: Solver
As I said in my first posting: >Please note that [the evaluation function] must be either EXPORTED, or you must fully qualify it in the call to Solve.SOLVE. so, if you EXPORT F, you should be able to do: Solve.SOLVE(F(X),X); However, I would suggest that you rename it to something else than F in order to avoid any possible funny business with the build in F variable. Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
