Free memory in HP Prime.
01-22-2014, 05:00 PM
How can I check how much free mem. I have left i HP Prime?
Thanks. |
01-22-2014, 05:57 PM
(This post was last modified: 01-22-2014 06:01 PM by Tim Wessman.)
RE: Free memory in HP Prime.
You can't.
There is a 256MB chip in there. You probably aren't running low. TW Although I work for HP, the views and opinions I post here are my own. |
01-22-2014, 06:58 PM
(01-22-2014 05:57 PM)Tim Wessman Wrote: You can't. I was just testing my beautiful prgm. to do implicit differentiation and it works fine until 3rd implicit differentiation of "x*y*e^(-1/2*x^2)-y" (this is just a test function). When I want to do 4th impl. diff. all creches badly. I thought maybe the calc. is running out of memory. Thanks. |
01-22-2014, 07:26 PM
There is only 32MB of ram of which approximate half is free on a clean boot. It is possible the program is consuming all of it, but more likely you've found a problem somewhere.
