Android Prime and hppgrm
10-12-2015, 02:46 PM
(This post was last modified: 10-12-2015 02:47 PM by ji3m.)
Does anyone know how to install an hppgrm into the prime emulator on an Android.
Doing this on a pc with a virtual prime is diffetent An unrooted android does not allow access to an app installation directory. Most app developers create an accessable directory for such things. I cant even figure out the name hp uses for the prime installation. So maybe it can't be done. Tell me it ain't so. I work with android Prime only for now on my Galaxy Tab Pro/Note 2 |
10-12-2015, 05:13 PM
RE: Android Prime and hppgrm
Copy and paste is the only way at the moment. If you are rooted, you can always put the files directly where they should be in the app data directory, but that isn't obviously a good solution.
