SETBASE() syntax error!
10-12-2015, 04:05 PM
(This post was last modified: 10-12-2015 04:06 PM by Spybot.)
I was trying to make some base conversions, and wasn't able to complete them because of this error! I want to say that this happens only on the virtual calculator, I'm using FW 8151, is it a bug? Spybot. |
10-12-2015, 05:11 PM
RE: SETBASE() syntax error!
Works fine here for me in either location. Anyone else?
10-12-2015, 07:52 PM
(10-12-2015 04:05 PM)Spybot Wrote: Hello! In the HOME settings set integers to "Decimal" and type the integer without "d": SETBASE(#8,1) :-) Best, Aries ;-) |
10-12-2015, 09:48 PM
(This post was last modified: 10-12-2015 09:49 PM by Spybot.)
In the last few weeks I've been trying out several programs on the Prime and it seems like they kind of mess around with the Emulator's settings or something, I reset the Emulator and now its working fine. The reason I posted this threat, was because I was using the correct syntax for the SETBASE() command and it kept giving me an error, so I thought it was an OS bug, but I see its not! From now on!...when ever I see a weird behavior on the Prime, I will do just a simple reset and probably it will fix it.
Aries, thank you for the tip, saving a couple of keystrokes! Thank you Tim and Aries for the feed back. Spybot. |
10-13-2015, 11:44 AM
You're welcome, Spybot !
Best, Aries ;-) |
