WP34s: Domain Error in RMDR and MOD
10-21-2015, 12:13 PM
(This post was last modified: 10-21-2015 12:15 PM by Dieter.)
I just noticed a strange behaviour of the RMDR and MOD functions. For large arguments they may return a "Domain Error". Some further investigation showed that these functions seem to work for y < 1E820 · x, and as soon as y gets larger the error occurs:
Code: [DBLON] Since the arguments are out of range in single precision mode, all this happens only after switching to double precision. Any idea what's going on here? Dieter |
10-21-2015, 09:39 PM
RE: WP34s: Domain Error in RMDR and MOD
The decNumber mod function isn't efficient and requires enough digits to represent the source numbers and the result (i.e. 2*384 + 16). I increase the number of carried digits for these operations to a little above this so that single precision never fails. I didn't go as far as supporting double precision -- there isn't sufficient RAM to do this directly.
Making double precision inputs work across the entire range will require a different algorithm and since we don't guarantee any results in double precision I didn't bother ![]() - Pauli |
10-22-2015, 01:00 PM
(10-21-2015 09:39 PM)Paul Dale Wrote: The decNumber mod function isn't efficient and requires enough digits to represent the source numbers and the result (i.e. 2*384 + 16). I increase the number of carried digits for these operations to a little above this so that single precision never fails. Wait... does this mean that RMDR and MOD internally use 400+ digits? (10-21-2015 09:39 PM)Paul Dale Wrote: Making double precision inputs work across the entire range will require a different algorithm and since we don't guarantee any results in double precision I didn't bother OK. Maybe a table with such restrictions would be helpful. I am also thinking of the distributions, Gamma and Beta with extreme cases of their parameters. Dieter |
10-22-2015, 09:57 PM
Mod uses 450 digits internally.
Modulo reduction by two pi for the trig functions uses 820. So in double precision, neither is adequate to support the entire range. Pauli |
