(48g) (49g) (50g) Rectangular to Polar Coordinate Conversion [RPL]
12-12-2013, 04:43 PM
(This post was last modified: 06-15-2017 01:30 PM by Gene.)
Although these two little RPL programs will work on the HP 28C/S, they are intended for later RPL calculators such as the HP 48S and HP 50g which lack this capability. Both programs accept the input parameters in the form of a complex number and return the results as individual values into the stack.
Rectangular to Polar Coordinates: << DUP ARG SWAP ABS >> Example: (3,4) --> 5 in stack level 1 and 53.13 in stack level 2 (degrees) Polar to Rectangular Coordinates: << DUP DUP RE SWAP IM SIN * SWAP DUP RE SWAP IM COS * >> Example: (5,53.13) --> 3 in stack level 1 and 4 in stack level 2 (degrees) |
12-13-2013, 08:58 AM
(This post was last modified: 12-13-2013 09:11 AM by Joe Horn.)
RE: Rectangular to Polar Coordinate Conversion [RPL]
Here's an alternate approach for Polar to Rectangular for HP 48/49/50, but it takes the inputs on two levels, not as a single complex number:
« -16 SF →V2 -16 CF V→ » <0|ɸ|0> -Joe- |
12-15-2013, 03:55 AM
That's actually very elegant and more in line with the methodology of calculators with direct conversion keys such as the HP 33s. The conversion in the other direction for rectangular to polar representation is:
<< -16 CF ->V2 -16 SF V-> >> |
12-17-2013, 06:30 AM
The only problem is that it does not preserve the user's original flag settings. A quick RCLF UNROT at the beginning and SWAP STOF at the end should fix it.
Graph 3D | QPI | SolveSys |
12-17-2013, 03:52 PM
(12-17-2013 06:30 AM)Han Wrote: The only problem is that it does not preserve the user's original flag settings. A quick RCLF UNROT at the beginning and SWAP STOF at the end should fix it. Well, you are correct about the UNROT at the beginning, but you need a ROT rather than a SWAP at the end to get the correct stack order. |
06-03-2014, 10:49 AM
(This post was last modified: 06-03-2014 11:20 AM by CosmicTruth.)
nice
NM! see this thread for 50G shoelaces http://www.hpmuseum.org/forum/thread-1522.html Thanks ~~~~8< Art >8~~~~ PS: Please post more 50G stuff :) |
06-03-2014, 11:19 AM
Alternatively, on the 50g PUSH ... POP
It ain't OVER 'till it's 2 PICK |
06-03-2014, 11:16 PM
(06-03-2014 11:19 AM)HP67 Wrote: Alternatively, on the 50g PUSH ... POP Code:
I like push-pops Thanks ~~~~8< Art >8~~~~ PS: Please post more 50G stuff :) |
