Sea stack
11-02-2015, 08:56 PM
Sea stack
Sometimes it is convenient to see what it is into stack, when no printer, to better programing. Here is a little routine that I use always on my HP41, with WP34s, I use Printer virtual. From PPC and HP41 examples book. Gérard. Gérard. |
11-03-2015, 08:17 PM
RE: Sea stack | |||
11-07-2015, 03:12 PM
RE: Sea stack
Thanks for posting the nifty little program.
Steve In order of appearance: HP 41CV, CMT-MCGPS, HP 41CX, DM 41, DM 42 |
11-07-2015, 03:52 PM
RE: Sea stack
Bonjour Gérard,
Merci pour ce petit programme. J'aime particulièrement la ligne 18 qui permet au programme d'être très compact. Cordialement, Sylvain ---- Hello Gérard, Thanks for this small program. By removing the unnecessary RDN or RUP in the main body, step 18 make it very compact Best regards, Sylvain |
11-08-2015, 12:32 AM
RE: Sea stack
Loop-unrolling saves 3 bytes but makes it 2 lines longer:
Code: 01 LBL "STKDISP" Kind regards Thomas |
11-08-2015, 02:38 AM
RE: Sea stack
(11-08-2015 12:32 AM)Thomas Klemm Wrote: Loop-unrolling saves 3 bytes but makes it 2 lines longer: Hello Thomas, Actually, it is 4 bytes shorter and effectively 2 lines longer. Kind regards, Sylvain Code: BB LL Thomas (48 Bytes) BB LL Gérard (52 Bytes) |
11-08-2015, 02:50 AM
RE: Sea stack | |||
11-08-2015, 11:02 AM
RE: Sea stack
Hi all,
Thank's for optimizations ! Gérard. Gérard. |
11-08-2015, 12:57 PM
RE: Sea stack | |||
11-08-2015, 01:37 PM
RE: Sea stack
(11-08-2015 12:57 PM)Dieter Wrote: OK, this requires a card reader... ;-) Or, at least, its ROM. Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
11-09-2015, 06:41 PM
RE: Sea stack
Xrom 30.33 for emulator. On real machine, without card reader, was.... Gérard. Gérard. |
11-09-2015, 07:16 PM
RE: Sea stack
(11-09-2015 06:41 PM)ggauny@live.fr Wrote: Hi, Yeah, you got it right (http://www.hpmuseum.org/software/xroms.htm). Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
11-10-2015, 06:42 PM
RE: Sea stack
Thank but I have already two cards readers.... Gérard. Gérard. |
11-10-2015, 08:01 PM
RE: Sea stack
(11-10-2015 06:42 PM)ggauny@live.fr Wrote: Hi, I don't even remember how many I have. Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
11-10-2015, 10:28 PM
RE: Sea stack
How you don't remember of this ? May I no good understand. I tink when we have, we remember Gérard. |
11-10-2015, 10:32 PM
RE: Sea stack
(11-10-2015 10:28 PM)ggauny@live.fr Wrote: Hi, When you got too many it is difficult to track everything. Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
11-10-2015, 10:38 PM
RE: Sea stack
I dont understand why you seem agressiv with me.
you have no understand my message. surely I was not clear. Yes i have two card reader for my 3 hp41( one C and two 41Cx) It was ma passion expensive. Really I dont understand your messages Gérard. |
11-10-2015, 10:43 PM
RE: Sea stack
Again in Piave ?
Gérard. |
11-11-2015, 01:58 AM
RE: Sea stack
Salut Gérard,
Je pense qu'il y a un problème de compréhensions entre vous et Massimo. Voici ma compréhension de vos échanges ... Vous: vous avez deux lecteurs de carte magnétique. Massimo: moi, je ne me souviens plus de comment j'en possède. Vous: Comment pouvez-vous ne pas vous souvenir de la quantité que vous avez ? Vous: Je n'ai probablement pas compris votre intervention. Vous: Normalement on devrait se souvenir de ce qu'on possède. Massimo: Lorsque tu en possèdes beaucoup, il arrive d'en perdre le décompte. Je ne pense pas que Massimo n'a été en aucun moment agressif dans ces échanges. Cordialement, Sylvain |
11-11-2015, 06:34 AM
RE: Sea stack
Thanks Sylvain, and sorry Gérard: I didn't mean to sound offensive nor aggressive.
Actually I, sometimes, find difficult to fully understand what you mean. My fault, of course. Massimo |
