Again a question !
11-10-2015, 07:19 PM
Again a question !
hi,
I see many times this : ggauny@live.fr Wrote: with a green arrow. How to do the same thing ? Thank for help me to do Gérard. Gérard. |
11-10-2015, 08:49 PM
RE: Again a question !
(11-10-2015 07:19 PM)ggauny@live.fr Wrote: hi, There's a button at the bottom of each post, saying "Quote". Clicking that should bring up a reply where you can enter your message in to reply to the quoted text. A bientôt... (Post 46) Regards, BrickViking HP-50g |Casio fx-9750G+ |Casio fx-9750GII (SH4a) |
11-10-2015, 09:17 PM
Bonsoir,
A bientôt surement ! Merci je vais essayer. Gérard Gérard. |
11-10-2015, 09:45 PM
(11-10-2015 08:49 PM)brickviking Wrote:(11-10-2015 07:19 PM)ggauny@live.fr Wrote: hi, Yes I go try your trik, it seem run, it is what I was to get. Yes it go, I see on prewiew Thank at you and Marcus ! Gérard. |
11-11-2015, 04:15 AM
RE: Again a question ! | |||
11-11-2015, 09:31 AM
As far as I know, all the phpBB forums mostly use the same tags.
Put [quote] and [/quote] around a part you want to quote. If you want to put who wrote it, do for example [quote="brickviking"] (and still end the quote with [/quote]). These are nestable. For a section of pre-formated code, put [code] and [/code] around it, and it will force monospacing and preserve your intensional extra spaces. To put something in bold, put [b] and [/b] around it. To put it in italics, put [i] and [/i] around it. For underline, put [u] and [/u] around it. To make a link, put [url= before the url and put ] at the end of the url, then put the text you want to show for the link, then end it with [/url]. To add an image by URL, put [img] and [/img] around the URL. For a bulleted list, put [list] and [/list] around it, and start each list item with [*]. You can have paragraph breaks within a single list item, before going on to the next list item. For a numbered or lettered list, start with [list=1] or [list=a] for example. You can also use [list]...[/list] to indent a whole section, without using [*]. [list]...[/list] is nestable too. There are others, but you get the idea. These are helpful if you want to do something that's not clear how to do with the icons at the top. http://WilsonMinesCo.com (Lots of HP-41 links at the bottom of the links page, http://wilsonminesco.com/links.html ) |
11-13-2015, 05:33 PM
(11-11-2015 09:31 AM)Garth Wilson Wrote: As far as I know ... And now just only one thing is not clear: how do you inserted these tags without the forum motor is not formatted the text between them?!? Haha... OK, I can see the quoted text in the editor and this is a really good trick... You simply inserts everywhere [size=small]...[/size] tag. Clever. Csaba |
