Add 1 Then Reciprocate and Fibonacci Numbers
11-15-2015, 07:18 PM
The Series ( ((((0 + 1)^-1 + 1)^-1 + 1)^-1 + 1)^-1 + 1)^-1 + … + 1)^-1 and Fibonacci Numbers.
I used the HP Prime to help me with this blog entry, in programming, plotting, and the CAS functions. http://edspi31415.blogspot.com/2015/11/t...1-1-1.html |
11-16-2015, 02:39 AM
RE: Add 1 Then Reciprocate and Fibonacci Numbers
You can calculate the limes as the fixed point of the iteration:
\[ x=\frac{1}{x+1} \] This results in: \[ x^2+x=1 \] There are two solutions. One of them is attractive: \(\frac{\sqrt{5}-1}{2}\approx 0.61803\). Cheers Thomas |
