Logic test returning unexpected answer
11-20-2015, 04:57 PM
2^(-x) == 1/(2^x) is returning 0. Any idea why?
11-20-2015, 05:08 PM
RE: Logic test returning unexpected answer
Not surprising, because == doesn't do any and all simplifications for you.
Try (x-1)*(x+1) == x^2-1 also returns 0.
But x^2-1 == x^2-1 returns 1.
11-20-2015, 05:31 PM (This post was last modified: 11-20-2015 05:38 PM by pwarmuth.)
Ok, that makes sense.
Speaking of simplifications, I encountered this today as well.
Those two statements should be mathematically identical, but yet their simplifications are not the same. I know for certain the second one is correct.
Though if I add in an explicit multiply, it behaves.
11-20-2015, 06:17 PM
Yes, don't skimp on the '*'!
11-20-2015, 10:05 PM
Using the method, simplify(f-g)==0, works pretty well - where f ang g are the two items being compared.
For example: simplify(2^(-x) - 1/(2^x))==0
11-20-2015, 10:42 PM (This post was last modified: 11-21-2015 01:23 PM by Fortin.)
(11-20-2015 05:31 PM)pwarmuth Wrote:  Ok, that makes sense.
This is because the intended implied multiplication involving 1/4 is calling 'of' instead of '*'.
