Starting a program through the app icons? [Solved]
11-25-2015, 08:00 PM
(This post was last modified: 09-06-2016 11:33 AM by jrozsas.)
how to start a program through the app icons?
I created a program. How to Inserting an APP icon to start the program without using the Programs menu? Example: My program "Area" (in Attachment) The "Area" program can be started by the Programs menu - Run ![]() But if I want to start the program by an icon in the app? I've tried copying and renaming an APP but not worked. ![]() ![]() Leo |
11-25-2015, 10:19 PM
RE: Starting a program through the app icons?
You can simply create a START function that runs the desired routine.
Graph 3D | QPI | SolveSys |
11-26-2015, 06:36 AM
Starting a "program" from the app icon screen can ONLY work if the program is an app program. To get a function in your program called upon the touch of the app icon, you need to have a function called START. This function will be called when the app is started. Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
11-26-2015, 11:09 AM
Thanks! Its work.
// CAS Custom Menu // EWS 2014-04-20 //ADAPTED BY João Leonardo Rozsas //leo8051@ig.com.br EXPORT Area() BEGIN END; SUB1(); SUB2(); SUB3(); SUB4(); SUB5(); SUB6(); START() BEGIN REPEAT //loop das subs LOCAL m,m1,mx,my; WHILE MOUSE(1)≥0 DO END; Leo |
