Looking for a 82120A, HP 41C rechargable battery pack
12-01-2015, 03:02 AM
Greetings all,
I am looking for a HP41C rechargeable battery pack to disassemble for measurements and 3d modeling. Dead, broken, etc is fine so long as I can get measurements from the case (internal and external).
My intention is to make a LiPO battery for my 41's, modeled off the 82120A. These housing models would be uploaded to shapeways similar to the port covers and battery holders I did before.
PM me here with price or email zulu at zombiebunniez dot us
Thanks
Nate
12-01-2015, 04:11 AM
RE: Looking for a 82120A, HP 41C rechargable battery pack
If you're USA address, I'll send you one free.
It's in poor condition as a battery pack, but apparently fine for what you need.
2speed HP41CX,int2XMEM+ZEN, HPIL+DEVEL, HPIL+X/IO, I/R, 82143, 82163, 82162 -25,35,45,55,65,67,70,80
12-01-2015, 04:15 AM
Thank-you, I got two offers pretty quick. Hopefully I will have some new models out for battery holders shortly.
12-01-2015, 04:17 AM
K,
disregard PM
01-05-2016, 02:22 AM
Got the prototype back today for the nicad case based on the 41 rechargeable battery pack. I think it looks OK...but should have done it in black.
[Image: 41 recharge pack 1.jpg][Image: 41 recharge pack 2.jpg][Image: 41 recharge pack 3.jpg][Image: 41 recharge pack 4.jpg][Image: 41 recharge pack 5.jpg][Image: 41 recharge pack 6.jpg][Image: 41 recharge pack 7.jpg]
The LiPO pack is still a work in progress with also the first prototype today, looks like everything fits so now I just need to lay out the circuit.
01-05-2016, 06:28 AM
(01-05-2016 02:22 AM)Nate Martin Wrote:  The LiPO pack is still a work in progress with also the first prototype today, looks like everything fits so now I just need to lay out the circuit.
Sounds interesting. Tell us more. I'm just about to rebuild one of those packs with 1/3 AAA NiMHs. Do you plan to have a DC-DC converter or run it straight from the LiPO? I thought about a LiPO, but the problem is that it doesn't have enough voltage to run the calc straight from the battery, and with a DC-DC converter, you need a separate power switch.
David Brunell
Houston, Texas
01-05-2016, 02:06 PM
Genius project.Really interested in the result. Maybe use oft 2S LiFePO4 pack makes DC converter obsolete. But then you do not have a capacity profit against 170 mAh NiMH 1/3 AAA cells.
01-27-2016, 06:03 AM
Completed rebuild of 41C NiCad case using new model, works ok and the model will be available on shapeways and thingiverse (http://www.thingiverse.com/thing:1296674). This allows use of legacy charging circuit with new batteries (1/3 AAA NiCad) and 3D printed case.
Now on to phase 2 the LiPo charging: series dischagre/ parallel charging in one case with a micro usb balance charging circuit.
01-27-2016, 06:47 AM
I wonder if i really am the only one with a rechargeable battery pack with a weird three-pin connector. All pictures i found so far have only two pins, including this one...
01-27-2016, 08:39 AM (This post was last modified: 01-27-2016 08:48 AM by Massimo Gnerucci.)
(01-27-2016 06:47 AM)damaltor Wrote:  I wonder if i really am the only one with a rechargeable battery pack with a weird three-pin connector. All pictures i found so far have only two pins, including this one...
You're not alone.
My oldest one has 3 pins.
Attached File(s) Thumbnail(s)
Greetings,
    Massimo
