MATLAB on Raspberry Pi 2, BeagleBone Black, ios, and Python
12-05-2015, 05:03 PM (This post was last modified: 12-05-2015 05:30 PM by compsystems.)
Undecided MatLab followed the steps of MATHEMATICA
0: raspberry-π
http://www.mathworks.com/hardware-suppor...atlab.html
1: beaglebone
[Image: 99786_wm_beaglebone-black-support-matlab-main.jpg]
2: i-OS
http://www.mathworks.com/hardware-suppor...ensor.html
I wish xCAS built-in on raspberry-π as mathematica (pre-installed in the current Raspbian-os image)
3: GETTING STARTED WITH MATHEMATICA
https://www.raspberrypi.org/learning/get...thematica/
12-05-2015, 08:13 PM
RE: MATLAB on Raspberry Pi 2, BeagleBone Black, ios, and Python
(12-05-2015 05:03 PM)compsystems Wrote:  0: raspberry-π
It sounded very interesting to me, but when I followed the link, I found this little piece of text: "Note that you cannot run MATLAB code as a standalone application on a Raspberry Pi."
Recently, one of my amateur astronomer buddies sent me a page of code he had written for Matlab. When I wanted to try it out for myself, I discovered that a Matlab license for a mere mortal like myself (no school/university connection) costs 2000 Euros. No Matlab for me then, whatever the platform might be...
Max
12-05-2015, 10:56 PM (This post was last modified: 12-06-2015 12:09 PM by Vtile.)
Max
Yep, Matlab is far from free or even cheap.. GNU Octave is free and is Matlab compatible in many ways, but I have never used it. IIRC there were some French goverment supprted Python related program also (might been Octave can't honestly recal atm.), which had Simulink a like interface.'
EDIT: SciLab is the software I were after. https://en.wikipedia.org/wiki/Scilab
12-06-2015, 07:25 PM
(12-05-2015 10:56 PM)Vtile Wrote:  EDIT: SciLab is the software I were after.
Used it in 2000/2001. There were only two or three documented differences from the Matlab language. Highly recommended!
12-07-2015, 11:51 AM
Thank you very much for the hint towards "Scilab". I had never heard of that! It ran instantly on my Macintosh without any configuration (seems to be written in Java) and could compute the Matlab code my colleague sent me.
This is the download link: http://www.scilab.org/
Best regards,
Max
12-08-2015, 01:31 AM
math-processor is open source and is inspired in matlab
http://mathiversity.com/math-processor/d...-functions
fibonacci = function (return, times, twoNumbersBack, oneNumberBack)
    if (times == 1) { return = twoNumbersBack;:}
    elseif (times == 2) { return = oneNumberBack;:}
    elseif (times == 3) { return = oneNumberBack + twoNumbersBack;: }
    elseif (times >= 0)
        return = fibonacci(times - 1, oneNumberBack, oneNumberBack + twoNumbersBack);:
    else
        echo("Error: Bad input."):
        return = -1;:
