Simplex Method updated to V20.13 (cas mode)
12-06-2015, 04:30 AM (This post was last modified: 12-18-2016 03:23 AM by cclinus.)
Update note:
Updated: 2016-12-17
sim20_13 : If there are infinitely many solutions, program will try to choose the smallest value.
Updated: 2016-12-9
sim20_11 : user definable variables name when importing data from Spreadsheet.
Use of argument:
sim20(0) : new input, no previous data.
sim20(1) : Load previous data.
sim20(2),sim20(3).... : Load and save data to "2","3".....
sim20(99) : Import data from spreadsheet.
Features:
1)Solve linear programming problem by simplex method.
2)Provide pure integer solution.
3)Provide Mixed integer, continuous and binary solution. (Read POST#6)
4)Save and reload data (Read POST#6)
5)Set target Z value (Read POST#6)
6)Import data from spreadsheet. (Read POST#10)
7)User definable variables name. (Read POST#11)
Simplex program is updated to v20.
First of all, try this example: Type sim20(0) in CAS mode.
Max X1 + 0.64X2
s.t. 50X1 + 31X2 <= 250
3X1 - 2X2 >= -4
X1 and X2 >=0 integers
Generally speaking, B&B should be more reliable. But above B&B solution is not optimal.
Why? It is because the searching level is not deep enough.
Pay attention to Reach Level: 5 ->6, it means the level limit is 5 but the program need to go to level 6 for more searching.
So, try to increase Search Level to 10.
Now, the solution is better and the Reach Level is 7.
It means the program is stopped at level 7 and no need to go deeper.
So, the solution should be optimal.
Example to use this program to find shortest path.
Set up the equations:
The solution is {1,0,1,0,0,1} Z=6, it means X12->X23->X34 is the shortest path.
Note that searching integer algorithm is time consuming, some problem may take one hour to solve. So, be patient.
Troubleshooting:
A) If you find sim20(0) is not working properly.
solution:
1) Delete sim17/18/19 if you have it before. Some function names are same.
2) Check cas variables by pressing [SHIFT] [Mem], then press "CAS Vars" , delete all rubbish function and sim17/18/19 related functions. Then press "Esc".
3) Press [SHIFT][Program],edit sim20_8, press softkey "Check", then "Esc" and "Esc".
4) Type sim20(0) in CAS mode to see whether it is working well. If not, repeat step 2 and 3.
B) Running non recursive evaluator ERROR
solution:
1) Press [SHIFT][CAS setting], go to page 2, set "Recursive Function" to 100.
C) Get Syntax error when pressing "CHECK" in program editor.
solution:
Put Spreadsheet App as the current App of calculator. Calculator title bar will show Spreadsheet App name. Then edit and CHECK program again.
sim20(0) codes:
EXPORT IMPORTDATA()
LOCAL C,V,P,S1,S2,S3,S4,S5;
LOCAL O,I,M,T,A,B,LEVEL;
LOCAL TAB,E,K,S,Z,FIX;
LOCAL METHOD,METHOD1,METHOD2,METHOD3,SUBLEVEL,INTGR;
LOCAL G,H,METHOD4,IMASK,BMASK;
LOCAL S6,S7,S8,S9;
LOCAL TT,SS,EE,OO,CC,MIXTAB,TEMP;
LOCAL ENDMARK1,ENDMARK2,VVV,CCC,NAMELIST;
LEVEL:=5;SUBLEVEL:=2;METHOD:=4;METHOD1:=0;METHOD2:=0;METHOD3:=0;INTGR:=0;METHOD4​:=0;
I:=0;
REPEAT
I:=I+1;
ENDMARK1:=(STRING(Cell(2,I))=="""end""" OR STRING(Cell(2,I))=="""END""" OR STRING(Cell(2,I))=="""MAX""" OR STRING(Cell(2,I))=="""max""" OR STRING(Cell(2,I))=="""MIN""" OR STRING(Cell(2,I))=="""min""");
UNTIL ENDMARK1;
V:=I-1;
I:=2;
REPEAT
I:=I+1;
ENDMARK2:=(STRING(Cell(I,1))=="""end""" OR STRING(Cell(I,1))=="""END""");
UNTIL ENDMARK2 ;
C:=I-3;
VVV:=V;CCC:=C;
INPUT({{VVV,[0],{55,20,0}},{CCC,[0],{55,20,1}},{INTGR,1,{55,20,2}},{LEVEL,[0],{55,20,3}},{METHOD,{"BRANCH & BOUND","CUTTING PLANE","Mixed B&C","ALL"},{55,42,4}},{METHOD4,1,{92,5,5}}},"SIMPLEX",{"NUMBER OF VARIABLES:","NUMBER OF CONSTRINTS:","INTEGER SOLUTION:","INTEGER SEARCH LEVEL:","METHOD:","MIXED INTEGER-CONTINUOUS-BINARY[0,1]:"});
IF CCC==0 OR VVV==0 THEN RETURN(0);END;
IF METHOD==1 AND INTGR==1 THEN METHOD1:=1;END;
IF METHOD==2 AND INTGR==1 THEN METHOD2:=1;END;
IF METHOD==3 AND INTGR==1 THEN METHOD3:=1;END;
IF METHOD==4 AND INTGR==1 THEN METHOD1:=1;METHOD2:=1;METHOD3:=1;END;
////////////// prepare variable //////////////////
O:=MAKELIST(0,X,1,V);
T:=MAKELIST(O,X,1,C);
E:=MAKELIST(0,X,1,C);
S:=MAKELIST(2,X,1,C);
IMASK:=MAKELIST(0,X,1,V);
BMASK:=MAKELIST(0,X,1,V);
////////////// Read Spreadsheet /////////////
H:=1;G:=0;NAMELIST:={};
FOR I FROM 1 TO V DO
IF TYPE(Cell(1,I))==2 THEN
NAMELIST(I):=Cell(1,I);
ELSE
NAMELIST(I):="X"+I;
O(I):=Cell(2,I);
END;//FOR I , Objective, variable name
I:=V+1;
ELSE
NAMELIST(I):="Z";
IF STRING(Cell(2,I))=="""MAX""" OR STRING(Cell(2,I))=="""max""" THEN P:=1;END;
IF STRING(Cell(2,I))=="""MIN""" OR STRING(Cell(2,I))=="""min""" THEN P:=2;END;
I:=V+2;
IF STRING(Cell(2,I))==""">=""" OR STRING(Cell(2,I))=="""≥""" THEN H:=2;END;
IF STRING(Cell(2,I))=="""<=""" OR STRING(Cell(2,I))=="""≤""" THEN H:=3;END;
IF STRING(Cell(2,I))=="""=""" THEN H:=4;END;
I:=V+3;
G:=Cell(2,I);
FOR K FROM 1 TO C DO
T(K,I):=Cell(K+2,I);
END;//FOR I, ==V
I:=V+1;
IF STRING(Cell(K+2,I))==""">=""" OR STRING(Cell(K+2,I))=="""≥""" THEN S(K):=1;END;
IF STRING(Cell(K+2,I))=="""<=""" OR STRING(Cell(K+2,I))=="""≤""" THEN S(K):=2;END;
IF STRING(Cell(K+2,I))=="""=""" THEN S(K):=3;END;
I:=V+2;
E(K):=Cell(K+2,I);
END;//FOR K, ==C
///// MIXED INT CONT BIN /////////////
IF METHOD4==1 THEN
S6:="";
S7:="";
S8:="";
M:=-1;
IF ((I MOD 3)==1) THEN L:=40;END;
IF ((I MOD 3)==2) THEN L:=40+27;END;
IF ((I MOD 3)==0) THEN L:=40+27*2;END;
IF ((I MOD 3)==1) THEN M:=M+1;END;
S6:=S6+"{IMASK("+I+"),1,{"+L+",5,"+M+"}},";
S7:=S7+""""+LEFT(NAMELIST(I),7)+""",";
END;//FOR I
S6:=S6+"{BMASK("+I+"),1,{"+L+",5,"+M+"}},";
S8:=S8+""""+LEFT(NAMELIST(I),7)+""",";
END;//FOR I
S6:=LEFT(S6,DIM(S6)-1);
S7:=RIGHT(S7,DIM(S7)-1);
S8:=LEFT(S8,DIM(S8)-1);
S8:=RIGHT(S8,DIM(S8)-1);
S9:="INPUT({"+S6+"},""CHOOSE INT. BIN. VARIABLES"",{""INTEGER: "+S7+"""BINARY: "+S8+"})";
EXPR(S9);
END;//METHOD4==1
//PRINT EQUATIONS
PRINT();
S1:="";
IF P==1 THEN S1:="MAXIMIZE: "+NAMELIST(V+1)+"= ";
ELSE S1:="MINIMIZE: "+NAMELIST(V+1)+"= ";END;
IF SIGN(O(I))==−1 THEN S1:=S1+" - ";END;
IF SIGN(O(I))≥0 AND I≠1 THEN S1:=S1+" + ";END;
S1:=S1+STRING(ABS(O(I)),7,-1)+"_"+NAMELIST(I);
END;//FOR I
/////// Target Z string //////////
IF H==2 THEN S1:=S1+" ≥ ";S1:=S1+G;END;
IF H==3 THEN S1:=S1+" ≤ ";S1:=S1+G;END;
IF H==4 THEN S1:=S1+" = ";S1:=S1+G;END;
PRINT(S1);
PRINT("SUBJECT TO:");
S1:="";
IF SIGN(T(K,I))==−1 THEN S1:=S1+" - ";END;
IF SIGN(T(K,I))≥0 AND I≠1 THEN S1:=S1+" + ";END;
S1:=S1+STRING(ABS(T(K,I)),7,-1)+"_"+NAMELIST(I);
END;//FOR I
IF S(K)==1 THEN S1:=S1+" ≥ ";END;
IF S(K)==2 THEN S1:=S1+" ≤ ";END;
IF S(K)==3 THEN S1:=S1+" = ";END;
IF SIGN(E(K))==−1 THEN S1:=S1+"-";END;
S1:=S1+STRING(ABS(E(K)),7,-1);
PRINT(S1);
END;//FOR K
PRINT("---------------------");
////////// Target Z equation /////////
IF H>1 THEN
T:=append(T,O);
E:=append(E,G);
S:=append(S,H-1);
C:=C+1;
END;//IF H>1
//Equal
FIX:=SIZE(S);
FOR I FROM 1 TO FIX DO
IF S(I)==3 THEN
S(I):=2;
C:=C+1;
T(C):=T(I);
E(C):=E(I);
S(C):=1;
END;//IF S(I)
END;//FOR I
///// SAVE T,E,S,O,C /////////////////////
TT:=T;
EE:=E;
SS:=S;
OO:=O;
CC:=C;
/////////// Construct TAB //////////////////
TAB:=append(T,(−1)^P*O);
TAB:=list2mat(TAB);
A:=MAKEMAT(0,1,C+1);
FOR I FROM 1 TO C DO
A:=A*0;
A(1,I):=(−1)^S(I);
ADDCOL(TAB,A(1),V+I);
Z:=MAKEMAT(0,1,C+1);
Z(1,C+1):=1;
ADDCOL(TAB,Z(1),C+V+1);
E:=append(E,0);
B:=list2mat(E,C+1);
ADDCOL(TAB,B(1),C+V+2);
/////////// Construct Mix TAB //////////////
IF METHOD4==1 THEN
//// constraint add X? <=1 BIN/////////
IF BMASK(I)==1 THEN
TEMP:=MAKELIST(0,X,1,V);
TEMP(I):=1;
TT:=append(TT,TEMP);
SS:=append(SS,2);
EE:=append(EE,1);
CC:=CC+1;
END;//IF BMASK==1
END;//FOR I
MIXTAB:=append(TT,(−1)^P*OO);
MIXTAB:=list2mat(MIXTAB);
A:=MAKEMAT(0,1,CC+1);
FOR I FROM 1 TO CC DO
A:=A*0;
A(1,I):=(−1)^SS(I);
ADDCOL(MIXTAB,A(1),V+I);
Z:=MAKEMAT(0,1,CC+1);
Z(1,CC+1):=1;
ADDCOL(MIXTAB,Z(1),CC+V+1);
EE:=append(EE,0);
B:=list2mat(EE,CC+1);
ADDCOL(MIXTAB,B(1),CC+V+2);
END;//IF method4==1
IMASK:=BITOR(IMASK,BMASK);
RETURN({TAB,C,V,P,LEVEL,SUBLEVEL,METHOD1,METHOD2,METHOD3,METHOD4,IMASK,MIXTAB,CC​,NAMELIST});
EXPORT INPUTDATA(REEDIT,REEDITBAG)
LOCAL S6,S7,S8,S9,NAMELIST;
IF REEDIT>=1 AND SIZE(REEDITBAG)==15 THEN
LEVEL:=REEDITBAG(15);
METHOD4:=REEDITBAG(14);
METHOD:=REEDITBAG(13);
INTGR:=REEDITBAG(12);
C:=REEDITBAG(5);
V:=REEDITBAG(6);
INPUT({{V,[0],{55,20,0}},{C,[0],{55,20,1}},{INTGR,1,{55,20,2}},{LEVEL,[0],{55,20,3}},{METHOD,{"BRANCH & BOUND","CUTTING PLANE","Mixed B&C","ALL"},{55,42,4}},{METHOD4,1,{92,5,5}}},"SIMPLEX",{"NUMBER OF VARIABLES:","NUMBER OF CONSTRINTS:","INTEGER SOLUTION:","INTEGER SEARCH LEVEL:","METHOD:","MIXED INTEGER-CONTINUOUS-BINARY[0,1]:"});
//INPUT({{V,[0],{55,20,0}},{C,[0],{55,20,1}},{LEVEL,[0],{55,20,2}},{METHOD1,1,{55,20,3}},{METHOD2,1,{55,20,4}},{SUBLEVEL,[0],{55,20,5}},{METHOD3,1,{55,20,6}}},"SIMPLEX",{"NUMBER OF VARIABLES:","NUMBER OF CONSTRINTS:","INTEGER SEARCH LEVEL:","CUTTING PLANE:","BRANCH & BOUND:","SUB CUT LEVEL:","MIXED BRANCH & CUT:"});
//INPUT({{V,[0],{55,20,0}},{C,[0],{55,20,1}},{LEVEL,[0],{55,20,2}},{METHOD2,1,{55,20,3}},{METHOD1,1,{55,20,4}},{SUBLEVEL,[0],{55,20,5}},{METHOD3,1,{55,20,6}}},"SIMPLEX",{"NUMBER OF VARIABLES:","NUMBER OF CONSTRINTS:","INTEGER SEARCH LEVEL:","BRANCH & BOUND:","CUTTING PLANE:","SUB CUT LEVEL:","MIXED BRANCH & CUT:"});
IF C==0 OR V==0 THEN RETURN(0);END;
IF V>REEDITBAG(6) THEN
FOR I FROM REEDITBAG(6)+1 TO V DO
REEDITBAG(4):=append(REEDITBAG(4),0);
REEDITBAG(10):=append(REEDITBAG(10),0);
REEDITBAG(11):=append(REEDITBAG(11),0);
FOR K FROM 1 TO REEDITBAG(5) DO
REEDITBAG(1,K):=append(REEDITBAG(1,K),0);
END;//FOR K
END;//FOR I
END;//IF larger V
IF V<REEDITBAG(6) THEN
REEDITBAG(4):=SUB(REEDITBAG(4),1,V);
REEDITBAG(10):=SUB(REEDITBAG(10),1,V);
REEDITBAG(11):=SUB(REEDITBAG(11),1,V);
REEDITBAG(1,K):=SUB(REEDITBAG(1,K),1,V);
END;//FOR K
END;//IF smaller V
IF C>REEDITBAG(5) THEN
FOR I FROM REEDITBAG(5)+1 TO C DO
REEDITBAG(2):=append(REEDITBAG(2),2);
REEDITBAG(3):=append(REEDITBAG(3),0);
REEDITBAG(1):=append(REEDITBAG(1),O);
END;//FOR I
END;//IF larger C
IF C<REEDITBAG(5) THEN
REEDITBAG(2):=SUB(REEDITBAG(2),1,C);
REEDITBAG(3):=SUB(REEDITBAG(3),1,C);
REEDITBAG(1):=SUB(REEDITBAG(1),1,C);
END;//IF larger C
////// RELOAD DATA ///////
T:=REEDITBAG(1);
S:=REEDITBAG(2);
E:=REEDITBAG(3);
O:=REEDITBAG(4);
P:=REEDITBAG(7);
G:=REEDITBAG(8);
H:=REEDITBAG(9);
IMASK:=REEDITBAG(10);
BMASK:=REEDITBAG(11);
END;//IF reedit==1
//PRINT("XXXXXXXX");
//PRINT(REEDITBAG(1));
//PRINT(REEDITBAG(4));
//PRINT(REEDITBAG(10));
//PRINT(REEDITBAG(11));
//PRINT(REEDITBAG(2));
//PRINT(REEDITBAG(3));
IF METHOD4==1 THEN
S6:="";
S7:="";
S8:="";
M:=-1;
IF ((I MOD 4)==1) THEN L:=25;END;
IF ((I MOD 4)==2) THEN L:=25+15;END;
IF ((I MOD 4)==3) THEN L:=25+15*2;END;
IF ((I MOD 4)==0) THEN L:=25+15*3;END;
IF ((I MOD 4)==1) THEN M:=M+1;END;
S7:=S7+"""X"+I+""",";
END;//FOR I
S8:=S8+"""X"+I+""",";
END;//FOR I
EXPR(S9);
END;//METHOD4==1
S1:="{P,{""Max"",""Min""},{1,17,0}}";
S3:="";
S4:="""Z"",";
M:=−1;
IF ((I MOD 3)==1) THEN L:=27;END;
IF ((I MOD 3)==2) THEN L:=27+27;END;
IF ((I MOD 3)==0) THEN L:=27+27*2;END;
IF (I MOD 3)==1 THEN M:=M+1;END;
S3:=S3+"{O("+I+"),[0],{"+L+",18,"+M+"}},";
S4:=S4+"""+X"+I+""",";
//////// Target Z /////////////
I:=V+1;
S3:=S3+"{H,{""Z"",""≥"",""≤"",""=""},{"+(L-8)+",9,"+(M)+"}},{G,[0],{"+(L+2)+",16,"+M+"}},";
S4:=S4+""""","""",";
S3:=LEFT(S3,DIM(S3)-1);
S5:="";
M:=M+1;
IF ((I MOD 3)==1) THEN L:=6;END;
IF ((I MOD 3)==2) THEN L:=6+24;END;
IF ((I MOD 3)==0) THEN L:=6+24*2;END;
S5:=S5+"{T("+K+","+I+"),[0],{"+L+",17,"+(M)+"}},";
S4:=S4+"""X"+I+""",";
S5:=S5+"{S("+K+"),{""≥"",""≤"",""=""},{72,9,"+(M)+"}},{E("+K+"),[0],{82,17,"+(M)+"}},";
S5:=LEFT(S5,DIM(S5)-1);
S4:=LEFT(S4,DIM(S4)-1);
S2:="INPUT({"+S1+","+S3+","+S5+"},""SIMPLEX"",{"+S4+"})";
EXPR(S2);
/////////////// SAVE VARIABLES FOR REEDIT ///////////////
REEDITBAG:=MAKELIST(0,X,1,15);
REEDITBAG(1):=T;
REEDITBAG(2):=S;
REEDITBAG(3):=E;
REEDITBAG(4):=O;
REEDITBAG(5):=C;
REEDITBAG(6):=V;
REEDITBAG(7):=P;
REEDITBAG(8):=G;
REEDITBAG(9):=H;
REEDITBAG(10):=IMASK;
REEDITBAG(11):=BMASK;
REEDITBAG(12):=INTGR;
REEDITBAG(13):=METHOD;
REEDITBAG(14):=METHOD4;
REEDITBAG(15):=LEVEL;
//PRINT EQUATIONS
PRINT();
S1:="";
IF P==1 THEN S1:="MAXIMIZE: Z= ";
ELSE S1:="MINIMIZE: Z= ";END;
S1:=S1+STRING(ABS(O(I)),7,-1)+"_X"+I;
END;//FOR I
PRINT(S1);
S1:="";
S1:=S1+STRING(ABS(T(K,I)),7,-1)+"_X"+I;
END;//FOR I
PRINT(S1);
END;//FOR K
IF H>1 THEN
T:=append(T,O);
E:=append(E,G);
S:=append(S,H-1);
C:=C+1;
END;//IF H>1
//Equal
FIX:=SIZE(S);
IF S(I)==3 THEN
S(I):=2;
C:=C+1;
T(C):=T(I);
E(C):=E(I);
S(C):=1;
END;//IF S(I)
END;//FOR I
TT:=T;
EE:=E;
SS:=S;
OO:=O;
CC:=C;
TAB:=list2mat(TAB);
A:=A*0;
A(1,I):=(−1)^S(I);
Z(1,C+1):=1;
E:=append(E,0);
B:=list2mat(E,C+1);
IF METHOD4==1 THEN
IF BMASK(I)==1 THEN
TEMP(I):=1;
SS:=append(SS,2);
EE:=append(EE,1);
CC:=CC+1;
END;//IF BMASK==1
END;//FOR I
A:=A*0;
A(1,I):=(−1)^SS(I);
Z(1,CC+1):=1;
EE:=append(EE,0);
END;//IF method4==1
NAMELIST:={};
NAMELIST(I):="X"+I;
END;//FOR I variable Name
I:=V+1;
NAMELIST(I):="Z";
RETURN({TAB,C,V,P,LEVEL,SUBLEVEL,METHOD1,METHOD2,METHOD3,METHOD4,IMASK,MIXTAB,CC​,REEDITBAG,NAMELIST});
#cas
caspivot(m,r,c):=BEGIN
local t,k,si;
t:=m;
si:=SIZE(m);
t[r]:=m[r]*(1/m[r,c]);
FOR k FROM 1 to si(1) DO
IF k≠r THEN
t[k]:=m[k]-m[k,c]*t[r];
END;//IF K≠RO
END;//FOR K
return(t);
#end
#cas
casphaseone(tab,c,v,stp1,intgr)
//PHASE ONE
local la,lb,alln,onezc;
local ill,lll,nse,nzn,nzr,k,i;
local rrr,mcl,w,maxi;
local ii,kk,ia,ib,nzb,nzbr;
onezc:=0;
REPEAT
FOR la FROM 1 TO c+1 DO
alln:=1;ill:=0;
FOR lb FROM 1 TO c+v+2 DO
IF tab[la,lb]>0 THEN alln:=0;END;
END;//FOR-LB
IF alln THEN tab[la]:=−1*tab[la];END;
END;//FOR-LA
nse:=0;lll:=0;
FOR i FROM 1 TO c+v DO
nzn:=0;nzr:=0;
FOR k FROM 1 TO c+1 DO
IF tab[k,i]≠0 THEN nzn:=nzn+1;nzr:=k;END;
END;//FOR-K
IF nzn≠0 THEN
IF (nzn==1) AND (nzr!=c+1) AND SIGN(tab[nzr,c+v+2])<0 AND SIGN(tab[nzr,i])<0 THEN tab[nzr]:=-1*tab[nzr];END;
IF (nzn==1) AND (nzr!=c+1) AND tab[nzr,c+v+2]==0 AND SIGN(tab[nzr,i])<0 THEN tab[nzr]:=-1*tab[nzr];END;
IF (nzn==1) AND (nzr!=c+1) AND (SIGN(tab[nzr,c+v+2])*SIGN(tab[nzr,i])<0 OR (tab[nzr,c+v+2]==0 AND SIGN(tab[nzr,i])<0)) AND (onezc==0)  THEN
alln:=1;
FOR lb FROM 1 TO c+v DO
IF SIGN(tab[nzr,c+v+2])*SIGN(tab[nzr,lb])>0 OR (tab[nzr,c+v+2]==0 AND SIGN(tab[nzr,lb])>0) THEN alln:=0;END;
END;//FOR-LB
IF alln==0 THEN
nse:=1;rrr:=nzr;lll:=i;
/////////////////// ADD same row check
FOR ia FROM 1 to c+v DO
IF ia!=lll THEN
nzb:=0;nzbr:=0;
FOR ib FROM 1 to c+1 DO
IF tab[ib,ia]!=0 THEN nzb:=nzb+1;nzbr:=ib;END;
END;//FOR ib (row)
END;//IF ia!=lll
IF nzb==1 AND nzbr==rrr AND tab[nzbr,ia]>0 THEN nse:=0;BREAK;END;
END;//FOR ia (COL)
ELSE
ill:=1;
END;//IF-ALLN
IF nse==1 THEN BREAK;END;
END;//IF-(NZN==1)
END;//IF-NZN≠0
//IF (NZN==1) AND (TAB(NZR,C+V+2)==0) AND (ONEZC==0)THEN NSE:=1;RRR:=NZR;LLL:=I;ONEZC:=1;END;
END;//FOR-I
IF nse==1 THEN
maxi:=0;mcl:=0;
IF (SIGN(tab[rrr,c+v+2])*tab[rrr,i]>maxi OR (tab[rrr,c+v+2]==0 AND tab[rrr,i]>maxi)) AND i≠lll THEN mcl:=i;maxi:=MAX(SIGN(tab[rrr,c+v+2])*tab[rrr,i],tab[rrr,i]);END;
//TAB(RRR):=TAB(RRR)/TAB(RRR,MCL);
tab:=caspivot(tab,rrr,mcl);
IF intgr==0 THEN PRINT("PHASE ONE: ROW="+rrr+" COL="+mcl);END;
stp1:=stp1+1;
UNTIL nse==0 OR stp1>=100;
return({tab,c,v,stp1});
#end
#cas
casphasetwo(tab,c,v,stp2,intgr):=BEGIN
local mini,neg,la,lb,alln,ook;
local i,k,j,r,q1,q2,pack,stp1;
local ookcol,ii,kk,nonzero,nonzerorow,nonzerorowlist;
stp2:=0;stp1:=0;
REPEAT
mini:=inf;neg:=0;
IF tab[c+1,c+v+1]<0 THEN tab[c+1]:=-1*tab[c+1];END;
alln:=1;
END;//FOR-LB
END;//FOR-LA
ook:=2;ookcol:=0;
FOR i FROM 1 TO v+c DO
IF (tab[c+1,i]<0) AND (tab[c+1,i]<mini) THEN
ook:=0;ookcol:=i;
FOR k FROM 1 TO c DO
IF tab[k,i]>0 THEN
ook:=1;
END;//IF2
END;//FOR-K
IF ook==1 THEN
mini:=tab[c+1,i];j:=i;neg:=1;
END;//IF3
END;//IF (tab[c+1,i]<0) AND (tab[c+1,i]<mini)
END;//FOR-I
/////////// TESTING ///////////////
IF ook==0 THEN
nonzerorowlist:=MAKELIST(X,X,1,c);
FOR ii FROM 1 TO c+v DO
nonzero:=0;nonzerorow:=0;
FOR kk FROM 1 TO c+1 DO
IF tab[kk,ii]!=0 THEN nonzero:=nonzero+1;nonzerorow:=kk;END;
END;//FOR kk
IF nonzero==1 THEN nonzerorowlist:=remove(nonzerorow,nonzerorowlist);END;
END;//FOR ii
IF SIZE(nonzerorowlist)!=0 THEN
IF tab[nonzerorowlist[1],ookcol]!=0 THEN
tab[nonzerorowlist[1]]:=-1*tab[nonzerorowlist[1]];
tab:=caspivot(tab,nonzerorowlist[1],ookcol);
IF intgr==0 THEN PRINT("TESTING: ROW="+nonzerorowlist[1]+" COL="+ookcol);END;
//PRINT("phaseone");
pack:=casphaseone(tab,c,v,stp1,intgr);
tab:=pack[1];
stp1:=pack[4];
neg:=2;
END;//IF tab[nonzerorowlist[1],ookcol]!=0
END;//IF SIZE(nonzerorowlist)!=0
END;//IF ook==0
IF neg==1 THEN
mini:=inf;r:=0;
IF tab[k,j]>0  THEN
IF RANDINT(1,2)==1 THEN
q1:=(tab[k,c+v+2]/tab[k,j])<mini;
ELSE
q1:=(tab[k,c+v+2]/tab[k,j])<=mini;
q2:=(tab[k,c+v+2]/tab[k,j])≥0;
IF  q1  THEN
mini:=tab[k,c+v+2]*(1/tab[k,j]);
r:=k;
tab:=caspivot(tab,r,j);
IF intgr==0 THEN PRINT("SIMPLEX: ROW="+r+" COL="+j);END;
tab:=pack[1];
stp1:=pack[4];
//RETURN(TAB);
//PRINT("OOK="+OOK);
stp2:=stp2+1;
//PRINT("stp2="+stp2);
UNTIL neg==0 OR stp2>=100;
return({tab,c,v,stp2,stp1,ook});
#end
#cas
cassimplex(tab,c,v,p,intgr,namelist):=BEGIN
local org,tempsimdata,retry;
local stp1,pack,pack2;
local s1,s2,s3;
local ABC,INFSOL,NSOL,SIG,temptab;
local stp2;
local nzr,nzn,r,t,mini;
local q1,q2,ook;
local ill2;
local mts,mtab,lmx;
local latab,ill3;
local i,k,simdata;
local nitem;
local solutionrow,m,samerow,firstpos,solutionlist;
local equ,posi,comment;
tab:=exact(tab);
org:=tab;
IF SIZE(namelist)!=(v+1) OR TYPE(namelist)!=6 THEN
namelist:={};
FOR i FROM 1 TO v DO
namelist[i]:="X"+i;
END;//FOR
namelist[v+1]:="Z";
END;//IF
//PHASE ONE
retry:=0;
REPEAT
stp1:=0;
pack:={};
tab:=pack[1];
//c:=pack(2);
//v:=pack(3);
stp1:=pack[4];
//SIMPLEX (Phase two)
stp2:=0;
pack:=casphasetwo(tab,c,v,stp2,intgr);
tab:=pack[1];
stp2:=pack[4];
stp1:=pack[5];
ook:=pack[6];
IF tab==org AND retry==0 THEN
retry:=1;
//PRINT("TEST");
FOR i FROM 1 to c+v DO
IF tab[c+1,i]==0 THEN
nitem:=0;
FOR k FROM 1 to c DO
IF tab[k,i]!=0 THEN nitem:=nitem+1;END;
END;//for k
IF nitem>1 THEN
mini:=inf;r:=0;
FOR t FROM 1 TO c DO
IF tab[t,i]>0 THEN
q1:=(tab[t,c+v+2]*(1/tab[t,i]))<mini;
q2:=(tab[t,c+v+2]*(1/tab[t,i]))≥0;
IF  q1  THEN
mini:=tab[t,c+v+2]*(1/tab[t,i]);
r:=t;
END;//IF q1 and q2
END;//IF SIGN
END;//FOR t
IF r!=0 THEN
tab:=caspivot(tab,r,i);
IF intgr==0 THEN PRINT("PIVOT: ROW="+r+" COL="+i);END;
BREAK;
END;//IF r!=0
END;//if nitem>1 (zero col)
END;//if last row==0
END;//for i
ELSE //END;//if tab==org
retry:=0;
UNTIL retry==0;
//orgtab:=tab;
//FIND VALID SOLUTION
IF intgr==0 THEN PRINT("---------------------");END;
latab:={};
latab[1]:=org;
/////////// Find multiple solutions list/////////////////////////
mts:={};
nzn:=0;nzr:=0;
FOR k FROM 1 to c+1 DO
IF tab[k,i]!=0 THEN nzn:=nzn+1;nzr:=k;END;
END;//FOR k
IF nzn>1 AND tab[c+1,i]==0 THEN mts:=append(mts,i);END;
END;//FOR i
lmx:={};lmx[1]:=tab;
/////////// PIVOT multiple col //////////////////////////////////
IF SIZE(mts)!=0 THEN
FOR i FROM 1 to SIZE(mts) DO
mini:=inf;r:=0;
IF tab[k,mts[i]]>0 THEN
q1:=(tab[k,c+v+2]*(1/tab[k,mts[i]]))<mini;
q2:=(tab[k,c+v+2]*(1/tab[k,mts[i]]))≥0;
IF  q1  THEN
mini:=tab[k,c+v+2]*(1/tab[k,mts[i]]);
r:=k;
END;//if q1 and q2
END;//if SIGN
END;//for k
IF r!=0 THEN
stp1:=0;
stp2:=0;
mtab:=caspivot(tab,r,mts[i]);
pack:=casphaseone(mtab,c,v,stp1,1);
pack2:=casphasetwo(pack[1],c,v,stp2,1);
lmx:=append(lmx,pack2[1]);
stp1:=pack2[5];
stp2:=pack2[4];
END;//IF r!=0
END;//FOR i (size(mts))
END;//IF size(mts)!=0
/////////// Find Solution ///////////////////////////////////////
solutionlist:={};simdata:={};
FOR m FROM 1 TO SIZE(lmx)(1) DO
// find solution row //////////////
solutionrow:={};mtab:=lmx[m];
nzn:=0;nzr:=0;
IF lmx[m,k,i]!=0 THEN nzn:=nzn+1;nzr:=k;END;
END;//FOR k
IF nzn==1 AND nzr!=c+1 THEN solutionrow[i]:=nzr;
ELSE solutionrow[i]:=0;END;
END;//FOR i
// Infinitely many solutions //////
NSOL:=0;INFSOL:={};INFSOL[1]:="";
FOR i FROM c+v DOWNTO 1 DO
equ:=" = ";
IF solutionrow[i]!=0 THEN
IF lmx[m,solutionrow[i],i]>0 AND (lmx[m,solutionrow[i],c+v+2]>0 OR lmx[m,solutionrow[i],c+v+2]==0)THEN
   INFSOL[NSOL+1]:="";
   firstpos:=0;
   IF i<=v THEN INFSOL[NSOL+1]:=" "+lmx[m,solutionrow[i],i]+"_"+namelist[i];firstpos:=1;END;
   IF i>v THEN equ:=" ≤ " ;END;
   samerow:=0;
   FOR k FROM i-1 DOWNTO 1 DO
       IF solutionrow[k]==solutionrow[i] THEN
          IF k<=v AND lmx[m,solutionrow[i],k]>0 THEN
             samerow:=1;
             firstpos:=1;
             SIG:=" - ";
             IF lmx[m,solutionrow[i],k]>= 0 THEN SIG:=" + ";END;
             INFSOL[NSOL+1]:=INFSOL[NSOL+1]+SIG+ABS(lmx[m,solutionrow[i],k])+"_"+namelist[k];
          END;//if k<=v
          IF k<=v AND lmx[m,solutionrow[i],k]<0 THEN
             IF firstpos==1 THEN samerow:=1;END;
             SIG:=" - ";
          solutionrow[k]:=0;
       END;//if same row
   END;//for k
   IF samerow==1 THEN  INFSOL[NSOL+1]:=INFSOL[NSOL+1]+equ+lmx[m,solutionrow[i],c+v+2];NSOL:=NSOL+1;INFSOL[NSOL+1]:="";END;
END;//if tab>0
IF lmx[m,solutionrow[i],i]<0 AND (lmx[m,solutionrow[i],c+v+2]>0 OR lmx[m,solutionrow[i],c+v+2]==0) THEN
   INFSOL[NSOL+1]:="";
   IF i<=v THEN INFSOL[NSOL+1]:=" "+lmx[m,solutionrow[i],i]+"_"+namelist[i];END;
   IF i>v THEN equ:=" ≥ ";END;
   samerow:=0;
   firstpos:=0;
   posi:=i;
       IF solutionrow[k]==solutionrow[posi] THEN
          IF k>v AND lmx[m,solutionrow[posi],k]>0 AND firstpos!=0 THEN
             solutionrow[k]:=0;
          IF k>v AND lmx[m,solutionrow[posi],k]>0 AND firstpos==0 THEN
             equ:=" ≤ ";
             firstpos:=1;
             solutionrow[posi]:=0;
             posi:=k;
          IF k>v AND lmx[m,solutionrow[posi],k]<0 THEN
             solutionrow[k]:=0;
          IF k<=v AND lmx[m,solutionrow[posi],k]>0 AND firstpos!=0 THEN
             solutionrow[k]:=0;
             samerow:=1;
             SIG:=" - ";
             IF lmx[m,solutionrow[posi],k]>= 0 THEN SIG:=" + ";END;
             INFSOL[NSOL+1]:=INFSOL[NSOL+1]+SIG+ABS(lmx[m,solutionrow[posi],k])+"_"+namelist[k];
          IF k<=v AND lmx[m,solutionrow[posi],k]>0 AND firstpos==0 THEN
             firstpos:=1;
             posi:=k;
             samerow:=1;
             SIG:=" - ";
          IF k<=v AND lmx[m,solutionrow[posi],k]<0 THEN
             solutionrow[k]:=0;
             SIG:=" - ";
          //IF k<=v AND lmx[m,solutionrow[posi],k]<0 AND firstpos==0 THEN
          //   solutionrow[k]:=0;
          //END;
       END;//if solutionrow==solutionrow and tab<0
   END;//for k
   IF samerow==1 THEN INFSOL[NSOL+1]:=INFSOL[NSOL+1]+equ+lmx[m,solutionrow[posi],c+v+2];NSOL:=NSOL+1;INFSOL[NSOL+1]:="";END;
   //IF firstpos==1 THEN solutionrow[i]:=0;END;
END;//if tab<0
END;//if solutionrow!=0;
END;//for i
IF NSOL>0 THEN ill3:=1; ELSE ill3:=0;END;
///////////// check infeasible solution /////////////////////////
ill2:=0;
   IF lmx[m,solutionrow[i],i]*SIGN(lmx[m,solutionrow[i],c+v+2])<0 THEN ill2:=1;END;
END;//IF solutionrow[i]!=0
END;//FOR i
s1:="";s2:="";s3:="";tempsimdata:={};ABC:=0;
///////////// prepare solution string ///////////////////////////
temptab:=lmx[m];
temptab[solutionrow[i]]:=temptab[solutionrow[i]]*(1/temptab[solutionrow[i],i]);
s1:=s1+namelist[i]+"="+STRING(temptab[solutionrow[i],c+v+2],7,-1)+" , ";
s2:=s2+namelist[i]+"="+STRING(temptab[solutionrow[i],c+v+2],14,-1)+" , ";
s3:=s3+namelist[i]+"="+STRING(temptab[solutionrow[i],c+v+2],2,4)+" , ";
tempsimdata:=append(tempsimdata,temptab[solutionrow[i],c+v+2]);
IF ROUND(temptab[solutionrow[i],c+v+2],0)!=temptab[solutionrow[i],c+v+2] THEN ABC:=1;END;
ELSE //ELSE solutionrow !=0
s1:=s1+namelist[i]+"=0 , ";
s2:=s2+namelist[i]+"=0 , ";
s3:=s3+namelist[i]+"=0 , ";
tempsimdata:=append(tempsimdata,0);
END;//IF solutionrow !=0
END;//FOR i
//////////////// Z /////
IF lmx[m,c+1,c+v+1]!=0 THEN
temptab:=lmx[m];
temptab[c+1]:=temptab[c+1]*(1/temptab[c+1,c+v+1]);
s1:=s1+namelist[v+1]+"="+STRING(((-1)^(p+1)*temptab[c+1,c+v+2]),7,-1);
s2:=s2+namelist[v+1]+"="+STRING(((-1)^(p+1)*temptab[c+1,c+v+2]),14,-1);
s3:=s3+namelist[v+1]+"="+STRING(((-1)^(p+1)*temptab[c+1,c+v+2]),2,4);
tempsimdata:=append(tempsimdata,(-1)^(p+1)*temptab[c+1,c+v+2]);
IF ROUND(temptab[c+1,c+v+2],0)!=temptab[c+1,c+v+2] THEN ABC:=1;END;
ELSE
s1:=s1+namelist[v+1]+"=NA"
s2:=s2+namelist[v+1]+"=NA"
s3:=s3+namelist[v+1]+"=NA"
tempsimdata:=append(tempsimdata,(-1)^p*inf);
//////////////// P /////
///////////// check NEW solution ///////////////////////////////
IF contains(solutionlist,tempsimdata)==0 THEN
solutionlist:=append(solutionlist,tempsimdata);
latab:=append(latab,lmx[m]);
///////////// PRINT solution ////////////
IF intgr==0 THEN
PRINT(s1);
IF s1!=s2 THEN
PRINT(s2);
IF ABC==1 THEN
PRINT(s3);
comment:=0;
IF ill3 AND (NOT ill2) THEN PRINT("*Infinitely many solutions*");
   PRINT("*Solution may satisfy below equation:*");
   FOR i FROM 1 TO NSOL DO
       PRINT(INFSOL[i]);
   END;//FOR NSOL
   comment:=1;
END;//IF ill3
IF ook==0 AND ill2==0 THEN PRINT("*Unbounded*");comment:=1;END;
IF ill2 THEN PRINT("*Infeasible solution*");comment:=1;END;
IF comment==1 THEN PRINT("---------------------");END;
END;//if intgr==0
//////////// prepare simdata ////////////
//IF ill4 THEN simdata[m*2-1]:=2;END;//multi
simdata:=append(simdata,0);
IF ook==0 AND ill2==0 THEN simdata[SIZE(simdata)]:=3;END;//unbounded
IF ill2==1 THEN simdata[SIZE(simdata)]:=1;END;//infeasible
simdata:=append(simdata,tempsimdata);
//PRINT("simdata="+simdata);
END;//if contains (solutionlist,tempsimdata)==0
END;//FOR m (solution tableau)
IF SIZE(simdata)>2 and intgr==0 THEN PRINT("*Multiple optimal solutions*");END;
IF intgr==0 THEN return(latab); END;
IF intgr==1 THEN return(simdata); END;
IF intgr==2 THEN return({latab,simdata});END;
#end
#cas
casintegerBB(tab,c,v,p,level,st,maxlevel,imask,bbormix,namelist):=BEGIN
local i,simdata,allinteger,newvector;
local newtab1,m,whichlevel,reachlevel;
local s1,s2,ABC;
whichlevel:=level;reachlevel:=level;
IF level==1 THEN
IF p==1 THEN best:={-inf};END;
IF p==2 THEN best:={inf};END;
allinteger:=0;
//PRINT("before simplex");
simdata:=cassimplex(tab,c,v,p,1,{});
//PRINT(level+":"+(simdata));
//PRINT("Level="+level+" best="+best+" new="+simdata);
//IF contains(simdata,{4,0,1,0,5})!=0 and b==0 THEN a:=tab;b:=1;END;
m:=0;
REPEAT
m:=m+1;
//if feasible solution
IF simdata[m*2-1]!=1 THEN
IF ((simdata[m*2,v+1]>=best[1]) AND p==1) OR ((simdata[m*2,v+1]<=best[1]) AND p==2)  THEN
allinteger:=1;
FOR i FROM 1 to v DO
IF imask[i]==1 THEN
IF ROUND(simdata[m*2,i],0)!=simdata[m*2,i] THEN
allinteger:=0;
reachlevel:=level+1;
IF level<maxlevel THEN
//PRINT("in level="+level+" simdata="+simdata+" m="+m+" i="+i);
//FLOOR ////////////////////////////////////////
newvector:=MAKELIST(0,X,1,c+v+2);
newvector[i]:=1;
newvector[c+v+2]:=FLOOR(simdata[m*2,i]);
newtab1:=tab;
ADDROW(newtab1,newvector,c+1);
newvector:=MAKELIST(0,X,1,c+1+1);
newvector[c+1]:=1;
ADDCOL(newtab1,newvector,v+c+1);
//PRINT("X"+i+" <= "+FLOOR(simdata[m,i]));
//st+CHAR(10)+"X"+i+" <= "+FLOOR(simdata[m,i])
whichlevel:=casintegerBB(newtab1,c+1,v,p,level+1,"",maxlevel,imask,bbormix,{});
IF whichlevel>reachlevel THEN reachlevel:=whichlevel;END;
//PRINT("pass FLOOR");
//CEILING//////////////////////////////////////
newvector[i]:=1;
newvector[c+v+2]:=CEILING(simdata[m*2,i]);
newtab1:=tab;
newvector[c+1]:=-1;
//PRINT("X"+i+" >= "+CEILING(simdata[m,i]));
//st+CHAR(10)+"X"+i+" >= "+CEILING(simdata[m,i])
END;//IF level<maxlevel
//return(newtab1);
END;//IF not integer
END;//IF imask==1
END;//FOR i
END;//if not better than best
END;//IF feasible solution
IF allinteger==1 THEN
IF simdata[m*2,v+1]==best[1] THEN
IF contains(best,simdata[m*2])==0 THEN
best:=append(best,simdata[m*2]);
//best:=INTERSECT(best,best);
END;//contains
ELSE
best:={0};
best[1]:=simdata[m*2,v+1];
best[2]:=simdata[m*2];
END;//equal
END;//if best P
END;//IF allinteger
//PRINT("m="+m+" simdata="+SIZE(simdata)+" "+simdata);
UNTIL m*2==SIZE(simdata);
IF level==1 THEN
//PRINT(best);
IF SIZE(best)>1 THEN
IF bbormix==0 THEN PRINT("Integer Solution [BRANCH & BOUND]");
ELSE PRINT("Mixed Solution [Mixed INT.CONT.BIN.]");END;
IF simdata[1]==3 THEN PRINT("*a possible solution*");END;
//IF reachlevel >= maxlevel THEN PRINT("*Try to increase search level for more solutions*");END;
//best:=mat2list(best);
m:=1;
REPEAT
m:=m+1;s1:="";s2:="";ABC:=0;
s1:=s1+namelist[i]+"="+best[m,i]+" , ";
s2:=s2+namelist[i]+"="+STRING(best[m,i],2,4)+" , ";
IF ROUND(best[m,i],0)!=best[m,i] THEN ABC:=1;END;
END;//FOR i
s1:=s1+namelist[v+1]+"="+best[m,v+1];
s2:=s2+namelist[v+1]+"="+STRING(best[m,v+1],2,4);
IF ROUND(best[m,v+1],0)!=best[m,v+1] THEN ABC:=1;END;
PRINT(s1);
IF bbormix==1 AND ABC==1 THEN PRINT(s2);END;
UNTIL m==SIZE(best);
ELSE
IF bbormix==0 THEN PRINT("*No solution [BRANCH & BOUND]*");
ELSE PRINT("*No Solution [Mixed INT.CONT.BIN.]*");END;
IF reachlevel>maxlevel THEN PRINT("*Try to increase search level*");END;
END;//if size(best)
//PRINT("-END-");
return(reachlevel);
END;//if level 1
return(reachlevel);
#end
#cas
casintegercut(tab,c,v,p,level,st,maxlevel,namelist):=BEGIN
local i,simdata,allinteger,newvector,pack,simtab;
local newtab1,m,k,cutrow,whichlevel,reachlevel;
local s1,noplaneerror,newdata,s2,ABC;
whichlevel:={};reachlevel:=level;noplaneerror:=1;newdata:={};
IF level==1 THEN
allinteger:=0;
//PRINT("Simplex");
//a:=tab;
pack:={};
pack:=cassimplex(tab,c,v,p,2,{});
simtab:=pack[1];
simdata:=pack[2];
//PRINT("pass simplex");
//a:=simtab;
//b:=simdata;
//IF level==1 THEN a:=simtab; END;
//PRINT(simdata);
//PRINT(exact(simtab));
m:=0;
REPEAT
m:=m+1;
//PRINT("feasbile="+m);
allinteger:=1;
//PRINT("Integer="+m);
allinteger:=0;
//PRINT("non integer="+m);
//FIND ROW /////////////////////////////////////
//PRINT("find row="+m);
//a:=simtab;
//b:=simdata;
cutrow:=0;
IF simtab[m+1,k,i]==1 THEN cutrow:=k;END;
END;//for k
IF cutrow!=0 THEN
FOR k FROM 1 to c+v+2 DO
newvector[k]:=simtab[m+1,cutrow,k]-FLOOR(simtab[m+1,cutrow,k]);
END;//FOR k
///no Plane ERROR
noplaneerror:=0;
FOR k FROM 1 to c+v+1 DO
IF newvector[k]!=0 THEN noplaneerror:=noplaneerror+1;END;
END;//FOR error K
IF noplaneerror!=0 THEN
newtab1:=simtab[m+1];
newvector[c+1]:=-1;
//return(newtab1);
//casintegercut ////////////////////////////////////////
//PRINT("enter next level");
whichlevel:=casintegercut(newtab1,c+1,v,p,level+1,"",maxlevel,{});
IF whichlevel[1]>reachlevel THEN reachlevel:=whichlevel[1]; END;
IF noplaneerror!=0 AND whichlevel[2]==0 THEN noplaneerror:=0;END;
newdata:=whichlevel[3];
END;//IF noplaneerror!=0
END;//IF cutrow!=0
//return(newtab1);
END;//FOR i
//PRINT("integer==1");
END;//contains
ELSE
best:={0};
END;//equal
END;//if best P
END;//IF allinteger
//PRINT("repeat");
//PRINT("XXXXXXXXXXXXXX");
//a:=simdata;
//b:=newdata;
IF newdata=={} THEN
newdata:=simdata;
//PRINT("YYYYYYYYYYYYYY");
IF level==1 THEN
//PRINT(best);
PRINT("Integer Solution [CUTTING PLANE]");
m:=1;
REPEAT
END;//FOR i
PRINT(s1);
//IF ABC==1 THEN PRINT(s2);END;
ELSE
PRINT("*No integer solution [CUTTING PLANE]*");
IF reachlevel > maxlevel THEN PRINT("*Try to increase search level*");END;
IF noplaneerror==0 THEN PRINT("*Try to use B&B*");END;
END;//if size(best)
//PRINT("-END-");
return({reachlevel,noplaneerror,newdata});
END;//if level 1
#end
#cas
casintegerBcut(tab,c,v,p,level,st,maxlevel,sublevel,namelist):=BEGIN
local s1,s2,ABC;
IF level==1 THEN
allinteger:=0;
//PRINT("integer cut");
//simdata:=cassimplex(tab,c,v,p,1);
//casintegercut(newtab1,c+1,v,p,level+1,"",maxlevel);
whichlevel:=casintegercut(tab,c,v,p,2,"",sublevel,{});
simdata:=whichlevel[3];
IF (whichlevel[1]-1)>reachlevel THEN reachlevel:=(whichlevel[1]-1); END;
//b:=simdata;
//a:=tab;b:=simdata;
m:=0;
REPEAT
m:=m+1;
IF simdata[m*2-1]!=1 AND simdata!={} THEN
allinteger:=1;
allinteger:=0;
newvector[i]:=1;
//y:=simdata;
//z:=simdata[m,i];
newtab1:=tab;
newvector[c+1]:=1;
whichlevel:=casintegerBcut(newtab1,c+1,v,p,level+1,"",maxlevel,sublevel,{});
newvector[i]:=1;
newtab1:=tab;
newvector[c+1]:=-1;
//return(newtab1);
END;//FOR i
END;//contains
ELSE
best:={0};
END;//equal
END;//if best P
END;//IF allinteger
IF level==1 THEN
//PRINT(best);
PRINT("Integer Solution [MIXED BRANCH & CUT]");
m:=1;
REPEAT
END;//FOR i
PRINT(s1);
ELSE
PRINT("*No integer solution [MIXED BRANCH & CUT]*");
END;//if size(best)
//PRINT("-END-");
return(reachlevel);
END;//if level 1
return(reachlevel);
#end
#cas
sim20(reedit):=BEGIN
local inputdata,tab,c,v,p,level;
local result,time1,time2,reachlevel;
local method1,method2,method3,sublevel;
local imask,method4,mixtab,cc,tempmask;
local namelist;
IF SIZE(reeditbag)<2 OR TYPE(reeditbag)!=6 THEN reeditbag:={{},{}};END;
IF reedit>=1 AND SIZE(reeditbag[reedit])!=15 THEN reeditbag[reedit]:={};END;
IF reedit==99 THEN
inputdata:=IMPORTDATA();
IF inputdata==0 THEN return(0);END;
tab:=exact(inputdata[1]);
c:=inputdata[2];
v:=inputdata[3];
p:=inputdata[4];
level:=inputdata[5];
sublevel:=inputdata[6];
method1:=inputdata[7];
method2:=inputdata[8];
method3:=inputdata[9];
method4:=inputdata[10];
imask:=inputdata[11];
mixtab:=inputdata[12];
cc:=inputdata[13];
namelist:=inputdata[14];
ELSE //IMPORTDATA
inputdata:=INPUTDATA(reedit,reeditbag[reedit]);
c:=inputdata[2];
v:=inputdata[3];
p:=inputdata[4];
cc:=inputdata[13];
reeditbag[1]:=inputdata[14];
namelist:=inputdata[15];
IF reedit>=2 THEN reeditbag[reedit]:=inputdata[14];END;
END;//INPUTDATA
IF method1==1 OR method2==1 OR method3==1 THEN intgr==1;
ELSE intgr==0;
result:=cassimplex(tab,c,v,p,0,namelist);
//IF intgr==0 THEN PRINT("-END-");END;
IF method1==1 THEN
tempmask:=MAKELIST(1,X,1,v);
time1:=TICKS;
reachlevel:=casintegerBB(tab,c,v,p,1,"",level,tempmask,0,namelist);
time2:=TICKS;
IF reachlevel<=level THEN PRINT("TIME="+STRING((time2-time1)/1000,2,3)+"sec        Reach Level: "+reachlevel);
ELSE PRINT("TIME="+STRING((time2-time1)/1000,2,3)+"sec        Reach Level: "+level+" -> "+reachlevel);
END;//IF reachlevel
END;//if Branch
IF method2==1 THEN
time1:=TICKS;
reachlevel:=casintegercut(tab,c,v,p,1,"",level,namelist);
time2:=TICKS;
IF reachlevel[1]<=level THEN PRINT("TIME="+STRING((time2-time1)/1000,2,3)+"sec        Reach Level: "+reachlevel[1]);
ELSE PRINT("TIME="+STRING((time2-time1)/1000,2,3)+"sec        Reach Level: "+level+" -> "+reachlevel[1]);
END;//if reachlevel
END;//if cut
IF method3==1 THEN
time1:=TICKS;
reachlevel:=casintegerBcut(tab,c,v,p,1,"",level,sublevel+1,namelist);
time2:=TICKS;
END;//IF reachlevel
END;//if Branch
IF method4==1 THEN
time1:=TICKS;
reachlevel:=casintegerBB(mixtab,cc,v,p,1,"",level,imask,1,namelist);
time2:=TICKS;
END;//IF reachlevel
END;//if Branch
PRINT("-END-");
return(result);
#end
.hpprgm  sim20_13.hpprgm (Size: 87.94 KB / Downloads: 135)
12-07-2015, 04:38 PM (This post was last modified: 11-11-2016 04:39 PM by jrozsas.)
RE: Simplex Method updated to V16
Very Good!
Leo
12-07-2015, 05:25 PM (This post was last modified: 12-07-2015 07:24 PM by jrozsas.)
(12-06-2015 04:30 AM)cclinus Wrote:  Sorry, very bad programming skill!
You can enter comments in the code for each line? This will help us better understand the program
Leo
10-07-2016, 02:08 PM (This post was last modified: 10-07-2016 02:12 PM by cclinus.)
RE: Simplex Method updated to V16 and V17(cas mode)
update CAS mode version sim17().
11-11-2016, 02:48 PM
RE: Simplex Method updated to V18(cas mode)
Simplex program is updated to v18, add integer solution and fixed some bugs.
11-19-2016, 10:51 AM (This post was last modified: 11-19-2016 11:45 AM by cclinus.)
RE: Simplex Method updated to V19(cas mode)
Simplex program is updated to V19. Below are the new features.
1) Mixed Integer Continuous and Binary [0,1] Solution
Example:
Max: 0.043X1+0.027X2+0.025X3+0.022X4+0.045X5
S.T. X1 + X2 + X3 + X4 + X5 <= 10
X2 + X3 + X4 >= 4
0.6X1+ 0.6X2 - 0.4X3 - 0.4X4 + 3.6X5 <= 0
4X1 + 10X2 - X3 - 2X4 - 3X5 <= 0
X1 is integer, X3 is binary, others are continuous number.
Solution = { 3 , 0 , 1 , 5.75 , 0.25 }
2) Target Z: You can specify a value for Z.
Z=no target value, "<=", ">=" or "=" with target value.
3) Mixed branch and cut method for integer solution.
May be I am not program it right, this method seems not reliable. Sometimes it can not provide the optimal solution. B&B is most reliable.
4) Allow re-edit and save data. This program use argument to save and reload data.
sim19(0): "0" zero, for clean input, no previous data.
sim19(1): always reload previous data.
sim19(2), sim19(3),sim19(4)....: save equation data into the file"2","3","4"... .
type sim19(2) to reload file"2" data.
If you want to copy previous data to "4", just type reeditbag(4):=reeditbag(1) in cas mode.
5) fix a bug
11-26-2016, 07:54 AM (This post was last modified: 11-26-2016 07:59 AM by cclinus.)
RE: Simplex Method updated to V19.8 (cas mode)
Minor update to v19.8.
fix a bug , a not unbounded solution misidentify as unbounded.
Hope it will not cause some new bugs!
Thanks!
11-26-2016, 03:00 PM
(11-26-2016 07:54 AM)cclinus Wrote:  Hi,
Thanks!
It does not work for me. Firmware 10637.
Do you have any user manuals? After entering values, no result appears
Leo
11-27-2016, 03:10 AM (This post was last modified: 11-27-2016 10:30 AM by cclinus.)
Hi Leo,
My is v10638, but it should work even on v8151(Android version).
Did you read troubleshooting? Does it help? Please check CAS Vars by press SHIFT Mem(B).
Delete all variables and re-download program again. Just press OK after key-in data to all input fields.
Can you post some screenshot?
Please let me know if it work eventually.
12-01-2016, 01:32 PM (This post was last modified: 12-01-2016 02:46 PM by cclinus.)
RE: Simplex Method updated to V20.8 (cas mode)
Simplex program is updated to V20.
This version add import data from spreadsheet. Since INPUT dialog box only allow to have 10 pages input fields at most. If your linear programming problem has many variables and constraints. It will cause invalid input ERROR. So, use spreadsheet as input interface could avoid this error from happen.
Below shows the standard format of spreadsheet.
In CAS mode, type sim20(99).
Make sure the name of the spreadsheet is on calculator's title bar.
Here are spreadsheet app example:
SimA(spreadsheet) has 25 variables with 10 constraints.
SimB(spreadsheet) has 2 variables with 2 constraints, just show the standard format.
.zip  simA.hpappdir.zip (Size: 1.95 KB / Downloads: 21)
.zip  SimB.hpappdir.zip (Size: 647 bytes / Downloads: 16)
Target Z value place here:
Thanks!
12-09-2016, 01:44 PM (This post was last modified: 12-10-2016 05:45 AM by cclinus.)
RE: Simplex Method updated to V20.11 (cas mode)
Simplex program is updated to v20.11
User is allowed to define the variables name when importing data from spreadsheet.
Below is an example: Type sim20(99)
Spreadsheet example:
.zip  SimD.hpappdir.zip (Size: 663 bytes / Downloads: 41)
02-08-2018, 09:19 PM
RE: Simplex Method updated to V20.13 (cas mode)
In new firmware 13333 dont work.
Erro sintaxe in ENDMARK1:=(STRING(Cell(2,I))=="""END""" OR STRING...
Leo
02-09-2018, 09:19 AM
This is not related to the version, but a different problem. Simplex 20.13 runs well on firmware 13333 I have on several devices (Android, Windows 10). Cool application, I like it a lot! Smile
Try to activate the "Spreadsheet" app on the Prime, then edit and "check" Simplex 20.13 again in the Program editor. It should work now and run while the Spreadsheet app is active.
02-09-2018, 10:45 AM (This post was last modified: 02-09-2018 10:46 AM by jrozsas.)
(02-09-2018 09:19 AM)goetz Wrote:  This is not related to the version, but a different problem. Simplex 20.13 runs well on firmware 13333 I have on several devices (Android, Windows 10). Cool application, I like it a lot! Smile
Thank you for your assistance. Actually when I opened the app "Spreadsheet" and checked the program, the line with error did not appear and everything worked.
Leo
03-29-2018, 10:34 PM
Hi, I am trying to run this program on firmware: 20180212 v13441 but it won't work, somebody with the same issue??
