Bug: Attempting to calculate a double sum crashes the CAS
12-07-2015, 10:06 PM
(This post was last modified: 12-08-2015 07:33 AM by quinyu.)
Calculating the following double sum causes a calculator crash:
While I understand that the closed form is nasty (involves the Psi function, plus the Euler-Mascheroni constant), the Prime could just say "no idea" instead of crashing. (Solution from Wolfram Alpha. TI nSpire CAS just returns the expression.) This is Software Version 2015 6 17 (8151), HW ver C, CAS version 1.1.2-11, OS 0.037.526 |
12-07-2015, 10:42 PM
RE: Bug: Attempting to calculate a double sum crashes the CAS | |||
12-07-2015, 10:54 PM
Does this work on Wolfram, Matlab, et al?
12-07-2015, 11:42 PM
(This post was last modified: 12-08-2015 07:34 AM by quinyu.)
12-08-2015, 07:41 AM
