How to simulate the escape key pressed
12-08-2015, 07:01 AM
I want to know in programming mode how to simulate escape key pressed and how to return to the catalog of programs after a STARTAPP (" Function ") and a .STARTVIEW(1). Thank you for your help. |
12-09-2015, 05:52 AM
RE: How to simulate the escape key pressed
you can not simulate the ESC key. However, you can switch view (to home, like ESC does, or other) by using the startview command. look at the help for more info (program catalog is startview(-7) Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
12-09-2015, 12:54 PM
OK that works... You are correct to the second question the answer was in the STARTVIEW () documentation. With apologies and thank you again for your help. |
