Bug or badly suboptimal result for derivative
12-18-2015, 03:18 PM
The CAS, when asked to derive the expression sin(x-cos x) returns a gigantic expression (I am not going to copy it here), containing imaginary units and otherwise close to unreadable.
The derivative could be properly determined according to the following steps (chain rule): f(u)=sin(u) => f'(u)=cos(u) f'(g(x))=cos(x-cos(x)) g(x)=x-cos(x) => g'(x)=1+sin(x), therefore dy/dx=f'(g(x))g'(x)=(cos(x-cos(x)))*(1+sin(x)) I am having software 2015.6.17 (8151); HW ver C; CAS ver 1.1.2-11; OS v0.037.526. |
12-18-2015, 03:39 PM
(This post was last modified: 12-18-2015 03:39 PM by CR Haeger.)
RE: Bug or badly suboptimal result for derivative
(12-18-2015 03:18 PM)quinyu Wrote: The CAS, when asked to derive the expression sin(x-cos x) returns a gigantic expression (I am not going to copy it here), containing imaginary units and otherwise close to unreadable. Works okay for me with CAS and Radians set. Get interesting results with Degrees set. |
12-18-2015, 03:49 PM
(This post was last modified: 12-18-2015 03:57 PM by Maro.)
which CAS settings do you use?
when using "Simplify: Minimum" (page 1 settings) I get the compact result as expected. However, when using "Simplify: Maximum" I get a very (!) large expression too. I would expect it the other way around ... really strange ... Edit: HP 50g: gives the expected (sin(x)+1)*cos(x-cos(x)) |
12-18-2015, 04:02 PM
(This post was last modified: 12-18-2015 04:38 PM by quinyu.)
I'm also set to radians. Also, Exact, Use Root, no Princ, no Comp, no i, simplify=maximum. I'd expect it to work at least as good as simplify=minimum...
By the way, the HP 50g finds the proper derivative. So does the TI-nSpire CAS, the TI-89 Titanium, the TI-92, Mathematica 10.0, Maple 18, MATLAB R2015a (in MuPAD as well as in the main prog). Casio ClassPad II emu 2.0000.4000 does well with it too. So something is happening that's pretty specific to the prime. |
12-18-2015, 08:24 PM
RE: Bug or badly suboptimal result for derivative | |||
12-18-2015, 09:23 PM
Settings I set as required, but I get a red X error for f:=(u) -> sin(u) already. How to resolve?
12-19-2015, 12:10 PM
That's weird. It only gives me the red X error when I do that assignment in Home. In CAS it works ok.
Sometimes I get strange random CAS variables that mess things up. I don't know what I do to get them but maybe you have some too. Check your CAS variables and reset any that look strange, also make sure you don't have f, g, u, x, etc. predefined as something strange. -road |
12-19-2015, 01:46 PM
Uhm, maybe I am wrong at some very basic level... is that a colon and an equal sign, after each other, or is that the symbolic depiction of some other (likely assignment) function? Because I have typed a : then an = in the input.
12-20-2015, 12:37 PM
A colon and an equal sign := is correct. Something else must be wrong. If you have an emulator you can try copy and pasting this:
f(u):=sin(u) or this: f:=(u)->sin(u) They should both give the same result. -road |
12-20-2015, 02:05 PM
Okay, now it works; no clue why it did not previously. Either way, even though I can now make the calculator to follow what I would do in that given situation (which is good for checking the procedure), I am still unable to get the calculator do it on its own. Are there any (hidden) switches to diff so as to influence the preference to the possible strategical steps in the evaluation tree?
12-21-2015, 03:18 PM
There are no hidden switches that I am aware of. I'm glad you got it working.
-road |
