82143A paper advance problem
12-30-2015, 07:06 PM (This post was last modified: 12-30-2015 07:09 PM by boniholmes.)
Hi to the Gurus,
I am a newbie here, and a proud owner of a HP-41CV and a 82143A printer. I have a problem with the latter, the paper advance does not work properly. It works for a few lines, then the calculator shows "Printer Error". I am not able to use the Paper Advance button when this happens. I tried to disassemble the printer, but do not know how to do it. I removed the screw in the center of the bottom plate, but was not able to remove it. Any help would be greatly appreciated.
Bon
HP-11, HP-41C, HP-41CV, HP-41CX, MATH/STAT, Surveying, X MEM, 82143A printer, 82104A card reader
12-30-2015, 10:41 PM
RE: 82143A paper advance problem
There are more screws under the rubber feet on the bottom.
12-31-2015, 05:31 AM
Hi Paul,
Thank you, that is what I suspected.
Bon
