(34S) Complex solver
01-07-2016, 10:16 PM (This post was last modified: 06-15-2017 01:21 PM by Gene.)
165 steps.
* CSV, an Ostrowski-Traub based complex solver
*   v1.5L (20160107) by M. César Rodríguez GGPL
* Usage:
*   Input:
*     XY: contains an initial root estimation. X is the real part, Y the
*         imaginary one
*     alpha: contains the name of the program to be solved. This program
*         is called with the stack (an SSIZE8 one) filled with a complex
*         estimation of the root. The program must return a complex
*         number in XY (X real, Y imaginary)
*   Output:
*     XY: the root found or the value of the last estimation for the
*         root. X real, Y imaginary
*     ZT: the value of the program to be solved evaluated at the
*         returned complex value in XY. Z real, T imaginary
*     LI: the input XY value
*     If the user interrupts the program ([<-] key), or the program to
*       be solved evaluates to infinity or NaN, or the solver reaches
*       its maximum iteration number (800 iterations), it ends with the
*       message "No root Found"
*   The user can interrupt the program pressing the [<-] key. If the
*     user interrupts the program with [EXIT] or [R/S], the values in
*     the stack, ABCD, L & I registers and flag D are not defined. Also,
*     the size of the stack will be 8. The same will occur if the
*     program to be solved throws an error (e.g. trying to access a non
*     existent register)
*   Register usage:
*     ABCD are cleared (no matter if the user works in SSIZE4 or SSIZE8)
*     Stack size is forced to 8 levels, but it is restored to the value
*       prior to calling the solver upon program end
*     Flag D is set (so function to be solved returns infinite or NaN
*       instead of reporting errors). This flag is restored to the value
* Algorithm:
*   The Ostrowski-Traub algorithm has 4th order convergence into
*     single roots. Requires 3 function evaluations on each iteration.
*     See, for example, [1]
*   For each root estimate z_i, a new estimate is computed with:
*       w_i = z_i - f(z_i)/f'(z_i)    (this is a Newton iteration)
*     where here the derivative f'(z_i) is estimated with:
*       f'(z_i) ~ (f(z_i + e_i) - f(z_i))/e_i
*   Thus, the expression used here to get the w_i estimate is:
*       w_i = z_i + e_i/(1 - f(z_i + e_i)/f(z_i))
*   Then, such estimate is refined with:
*       z_{i+1} = w_i - f(w_i)(z_i - w_i)/(f(z_i) - 2f(w_i))
*     which  is implemented here as:
*       z_{i+1} = w_i + (z_i - w_i)/(2 - f(z_i)/f(w_i))
*   After each iteration, |z_{i+1} - z_i| is checked to be smaller
*     than max(|z_i|/10^4, 10^-8). If so, a flag is set signaling that
*     the algorithm is "converging". This flag remains set until
*     program end
*   After each iteration and if the algorithm is "converging",
*     |z_{i+1} - z_i| is compared to |z_i - z_{i-1}|, being greater the
*     algorithm is supposed to had converged and z_i (not z_{i+1}) is
*     declared a root. This stopping algorithm is, basically, the Ward's
*     criterion [2]
*   The program will also exit with a root found (hopefully) if:
*     - evaluating the program to be solved returns 0 + 0j
*     - f(z_i + e_i) = f(z_i)
*     - z_{i+1} = z_i
*   The program will exit with error message "No root Found" if:
*     - evaluating the program to be solved returns Infinite or NaN
*     - the algorithm reaches 800 iterations (in DBLOFF mode and with
*         single roots, the algorithm many times needs only 3 iterations
*         to converge)
*     - the user interrupts the program pressing [<-]
*   When a root is found, it is "beautified" by:
*     - changing numbers like 1.124999999973587 or 1.125000000032518
*       to 1.125. The code for this is adapted from the PRS polynomial
*       solver for the wp34s by Franz Huber
*     - numbers with an imaginary (real) part much smaller than its
*       real (imaginary) part, are converted to real (imaginary) ones
*       zeroing the smaller part
*     Then, the function to be solved is evaluated at this new,
*     beautified, root and it the value of the function is closer
*     (or equally close) to 0, then the beautified root is returned as
*     the root
*   When estimating the value of the derivative f'(z_i) with:
*     (f(z_i + e_i) - f(z_i))/e_i, the increment e_i is:
*     - if z_i is real, then
*         e_i = |z_i - z_{i-1}|/10^3
*     - otherwise
*         e_i = |z_i - z_{i-1}|/10^3·exp(j·ai), with a_i a random
*         angle between 0 and 2·pi
*     Thus, if the function to be solved is real valued for real
*     arguments and the initial root estimate is real, the program
*     will only search for real roots
* When called from another program, this solver will behave like a
*   test, executing next program step when a root is found, or
*   skipping it when not found
* This solver does also work in DBLON mode
* References:
*   [1] Wei-hong, B.I., Qing-biao, W.U., Hong-min R. "Convergence ball
*     and error analysis of Ostrowski-Traub’s method." Appl. Math. J.
*     Chinese Univ. 2010, 25(3): 374-378
*   [2] Ward, R.C. "The QR algorithm and Hyman’s method on vector
*     computers." Mathematics of Computation 01/1976; 30(133): 132-132
          LBL'CSV'          // Complex SolVer
            LocR 16         // Local registers and flags:
                            //  .00       mode
                            //  .01       |d_i| (that's |z_i - z_{i-1}|)
                            //  .02-03    z_i
                            //  .04-05    e_i
                            //  .06-07    f(z_i)
                            //  .08-09    z_0
                            //  .10       iteration counter
                            //  .11       fname
                            //  .12-13    w_i
                            //  .14-15    arg, argument for program to
                            //            solve, also beautified zi
                            //  F.00      no convergence, or f evaluates
                            //            to special, or user interrupt
                            //  F.01      algorithm is converging
                            //  F.02      backup of D flag
            STOM .00        // STOM mode. Mode is restored at exit
            SSIZE8
            FS? D           // backup flag D
              SF .02
            SF D            // specials are not errors here
            aSTO .11        // aSTO fname. Name of function to solve
            cSTO .08        // cSTO z0. Initial guess
            cSTO .02        // cSTO zi. Estimate
            cABS            // |z0|
            x=? Y           // |z0| = 0?
              # 001
            SDR 005         // |d0| = |z0| / 10^5, or 10^-5 if |z0| = 0
            STO .01         // STO |di|
            # 080
            SDL 001         // 800, maximum iter #
            STO .10         // STO counter
            // first pass, Newton's estimate
CSV_mloop:: cRCL .02        // cRCL zi
            GSB CSV_eval    // eval function, check for special or root
              JMP CSV_exit  // if result is special or root, exit
            cSTO .06        // cSTO f(zi)
            // compute e_i to estimate derivative
            RCL .03         // RCL Im(zi)
            # 000
            x=? Y           // zi is real?
              JMP CSV_noai  // yes, e_i must also be real
            ACOS            // no. pi/2 (or 90º or 100 grad)
            # 004
            RAN#
            *               // ai, random angle between 0 and 2pi
CSV_noai::  RCL .01         // RCL |di|. ai or 0 in Y
            SDR 003         // |di|/10^3
            >REC
            cSTO .04        // cSTO ei
            // estimate derivative
            cRCL+ .02       // RCL+ zi. zi + ei
            GSB CSV_eval    // f(zi + ei)
            cRCL/ .06       // cRCL/ f(zi). f(zi + ei)/f(zi)
            cCHS            // -f(zi + ei)/f(zi)
            INC X           // 1 - f(zi + ei)/f(zi)
            cx=0?           // f(zi + ei) = f(zi)?
              JMP CSV_exit  // then exit (converged)
            cRCL .04        // cRCL ei
            cRCL/ Z         // ei/(1 - f(zi + ei)/f(zi))
            cRCL+ .02       // cRCL+ zi. zi + ei/(1 - f(zi + ei)/f(zi))
            cSTO .12        // cSTO wi. New wi
            // 2nd pass, Ostroswki's refine
            GSB CSV_eval    // f(wi)
            cRCL .06        // cRCL f(zi)
            cRCL/ Z         // f(zi)/f(wi)
            DEC X
            DEC X           // f(zi)/f(wi) - 2
            cRCL .12        // cRCL wi
            cRCL- .02       // cRCL- zi. wi - zi
            cRCL/ Z         // (wi - zi)/(f(zi)/f(wi) - 2)
            cRCL+ .12       // wi + (zi - wi)/(2 - f(zi)/f(wi)) (zi+1)
            // compute new |di| for next derivative estimation and check
            // convergence
            cFILL           // stack filled with zi+1
            cRCL- .02       // cRCL- zi. zi+1 - zi
            cABS            // |zi+1 - zi| (|d_{i+1}|)
            x=0?            // zi+1 = zi?
            cRCL .02        // cRCL zi
            cABS            // |zi|
            SDR 004         // |zi|/10^4
            # 001
            SDR 008         // 10^-8
            MAX             // max(|zi|/10^4, 10^-8)
            x>? Z           // |zi+1 - zi| < max(|zi|/10^4, 10^-8)?
              SF .01        // yes, algorithm is converging
            x<> Z           // |zi+1 - zi|
            FC? .01         // converging?
              JMP CSV_updt  // no, skip convergence test
            x>? .01         // converged?
CSV_updt::  STO .01         // STO |di|
            cRCL A          // cRCL zi+1
            cSTO .02        // cSTO zi
            // check user interrupt
            KEY? X          // any key?
              JMP CSV_nok   // no, continue
            # 035           // keycode for <-
            x=? Y           // key is [<-]?
              JMP CSV_flag  // yes, mark as no root found and exit
            // check iteration limit #
CSV_nok::   DSZ .10         // DSZ counter
            JMP CSV_mloop   // goto main loop
CSV_flag::  SF .00          // flag no root found
            // root found (F.00 reset) or not (F.00 set)
CSV_exit::  FS? .00         // no root?
              JMP CSV_nopp  // no root, skip post process
            // beautify x.xx...999999xxxx and x.xx...000000xxxx roots
            cRCL .02        // cRCL zi
            cSTO .14        // save zi in arg
            RSD 11          // Re(zi) rounded to 11 digits
            x<> .14
            RSD 09          // Re(zi) rounded to 9 digits
            x!=? .14        // rounded to 11 digits != rounded to 9?
              RCL L         // yes, keep Re(zi) untouched
            STO .14         // otherwise, use new, beautified, value
            RCL .15         // RCL Im(zi)
            RSD 11          // Im(zi) rounded to 11 digits
            x<> .15
            RSD 09          // Im(zi) rounded to 9 digits
            x!=? .15        // rounded to 11 digits != rounded to 9?
              RCL L         // yes, keep Im(zi) untouched
            STO .15         // otherwise, use new, beautified, value
            // beautify almost real/imaginary roots
            cRCL .14        // cRCL zi (partially beautified)
            EXPT
            x<> Y
            EXPT
            -               // orders of magnitude between Re and Im
            # 011
            x<? Y           // almost real?
              JMP CSV_real  // yes, convert to real
            CHS
            x<? Y           // almost imaginary?
              JMP CSV_chkb  // no, keep intact. Check new zi
            # 000           // here if almost imaginary, clear Re
            STO .14
            JMP CSV_chkb    // zi beautified, check it
CSV_real::  # 000           // here if almost real, clear Im
            STO .15
            // check if beautified zi is a better root
CSV_chkb::  cRCL .14        // cRCL zi (beautified)
            cx=? .02        // beautified zi = zi?
              JMP CSV_nopp  // yes, no need to check, skip
            GSB CSV_eval    // compute f(zi) for beautified zi
              JMP CSV_nopp  // beautified zi lets f(zi) special, skip...
                            // or is a true root, also skip
            cENTER
            cABS            // abs(f(zi)) with zi beautified
            cRCL .06
            cABS            // abs(f(zi)) with zi non-beautified
            x<? Z           // the beautified zi is no better?
              JMP CSV_nopp  // yes, keep root intact
            cRCL A          // yes, root is the new zi. cRCL f(zi)
            cSTO .02        // cSTO zi (beautified)
            // build return stack
CSV_nopp::  cRCL .08        // cRCL z0
            cSTO L          // input argument copied to LI
            CLSTK           // tidy stack (A-D lost)
            FC? .02         // restore user's D flag
              CF D
            RCLM .00        // RCLM mode, restore user mode
            cRCL .02        // cRCL zi. Now f(zi), zi on stack
            cVIEW .02       // cVIEW zi, show root in complex form
            FC? .00         // root found?
              RTN           // yes, that's enough
            MSG 20          // no, report it
          RTN+1             // to behave like a test
            // wrapper for program to be solved. Saves the argument,
            // fills the stack and checks return value. Behaves like
            // a test. The test returns false if the return value is
            // neither special nor zero. Returns true otherwise,
            // setting flag .00 if return value is special or storing
            // 0+0j in f(zi) and the argument in zi if the argument is
            // a root
CSV_eval::  cSTO .14        // cSTO arg. Save argument
            cFILL
            aXEQ .11        // evaluate f
            SF .00
            SPEC?           // Re(f) is special?
              RTN           // yes, test returns true & F.00 set
            x<> Y
            SPEC?           // Im(f) is special?
            x<> Y
            CF .00
            cx!=0?          // argument is not a root?
              RTN+1         // not a root, test returns false
            cSTO .06        // cSTO f(zi). Is a root, save 0+0j in f(zi)
            cRCL .14        // cRCL arg
            cSTO .02        // cSTO zi. Store the root in zi
            RTN             // test returns true & F.00 reset
        END
