User Keys RPN
01-09-2016, 08:56 PM
User Keys RPN
So I'm trying to shortcut the CONVERT() in RPN to make my life easier. I my program is easy
KEY K_Eex()
RETURN "CONVERT()";
but when I use the user key in RPN it just prints the convert then I have to press OMG [ENTER] all over again. This makes me grumpy. Does anyone know how I can just tell it to press enter for me and trust me that I'll use it where I will need it?
I was thinking it should look like this
KEY K_Eex()
RETURN "CONVERT()";
// Some code here that presses enter for me
-Luis-
01-09-2016, 09:32 PM
RE: User Keys RPN
What I'm about to show you is sad. But found a hack to make what I want work. You had KILL; Before the end of the program
KEY K_Eex()
RETURN "CONVERT()";
KILL;
So in RPN mode type
30_deg [ENTER]
1_rad [ENTER]
[Shift]
[Help]
[EXX]
0.52....._rad
It seems that KILL; presses enter for you or something.
I think this might work for a bunch of other functions too.
-Luis-
01-10-2016, 09:56 PM
RE: User Keys RPN
(01-09-2016 09:32 PM)luisphysics Wrote:  What I'm about to show you is sad. But found a hack to make what I want work. You had KILL; Before the end of the program
KEY K_Eex()
RETURN "CONVERT()";
KILL;
So in RPN mode type
30_deg [ENTER]
1_rad [ENTER]
[Shift]
[Help]
[EXX]
0.52....._rad
Does not work here :-(
01-11-2016, 02:12 AM
RE: User Keys RPN
Are you using the physical calculator or are you using one of the apps? Because this works on my calculator but not on the iOS version
-Luis-
01-11-2016, 04:12 AM
RE: User Keys RPN
(01-11-2016 02:12 AM)luisphysics Wrote:  Are you using the physical calculator or are you using one of the apps? Because this works on my calculator but not on the iOS version
Physical Calculator, latest firmware.
But I admit I did not try your solution with your exact inputs. I use a different key assignment and a different return statement. I will try it exactly as you typed and report.
François
