[secret functions] Chinese character helper?
01-28-2014, 05:41 AM
(This post was last modified: 01-28-2014 05:42 AM by eried.)
I was working on this beauty:
![]() when I notice that when you type a letter when selecting a character: ![]() You get another grid with number as options: ![]() And then you get like a subset of chinese characters: ![]() ________ Has anyone found another "little secrets"? ________ Other: ON+T: Show terminal ON+E, ON+ESC: Exam configuration Integer editor, if you have a #number in your stack and empty entry, calling Shift+Base again will pop a little editor (where you can actually drag to edit or just modify an binary with the cursor keys, pretty sweet): ![]() My website: ried.cl |
01-28-2014, 07:44 AM
RE: [secret functions] Chinese character helper?
I'm not sure if it is really 'secret', 'cause if you scroll down the 'more' menue you'll find lots more of chinese, japanese and other asian characters. The menue entries usually begin with 'CJK'.
Best regards Karl |
01-28-2014, 02:08 PM
(This post was last modified: 01-28-2014 02:27 PM by compsystems.)
more secrets
list[1,2,3]; returns {1,2,3} // converts a list folder[]; returns [[]] ? unknown in spn =( el editor decodifica &&, || como equivalentes a and, or true && false; returns 0 // only CAS MODE true || false; returns 1 // only CAS MODE comilla simple como diff y:= x^2; { y', y'', y''' }; returns {2*x,2,0} // only CAS MODE != como diferente 5!=7; returns 1 PD: como requerimiento, observando la captura de pantalla, Erwin puedes agregar por favor otras opciones como ver alfabeto griego minúsculas Quote:"α Alfa, β Beta, γ Gamma, δ Delta, ε Épsilon, ζ Dseta, η Eta, θ Theta, ι Iota, κ Kappa, λ Lambda, μ Mi, Greek en mayusculas Quote:"Α ALFA, Β BETA, Γ GAMMA, Δ DELTA, Ε ÉPSILON, Ζ DSETA, Η ETA, Θ THETA, Ι set de caracteres ASCII 7 bits {0, .... 127 } set de caracteres extendido ASCII 8 bits {128, .... 256 } este facilita la inserción de caracteres acentuados, útiles en especial en lengua castellana, francés, portugués Quote:"ÀÁÂÃÄÅÆÇÈÉÊËÌÍÎÏÐÑÒÓÔÕÖ ØÙÚÛÜÝÞßàáâãäåæçèéêëìíîïðñòóôõö øùúûüýþÿ" |
05-10-2015, 07:55 PM
(01-28-2014 05:41 AM)eried Wrote: I was working on this beauty: You are the man, thank you for posting this. ![]() |
05-11-2015, 05:32 AM
assuming that a contains a binary integer,
a(1) returns bit 1 of a... or allows to store something there.. of course, if object 2 of list 1 is a binary integer, you can also do L1(2,2) to access bit 2 of that integer). cyrille |
