possible problem INPUT dialog box
01-18-2016, 10:58 PM
(This post was last modified: 01-18-2016 11:24 PM by compsystems.)
Hello
within the INPUT dialog box, if you press any menu, [ESC], [OK], [EDIT] is blocked, also the input must be greater than 100 has been tested only in the emulator PHP Code: EXPORT p11_repeat_block() |
01-19-2016, 06:01 AM
RE: possible problem INPUT dialog box
The issue here are your wait. They cause the calculator to pause, waiting for a key press. During this time, the calculator will not respond to anything else. I suggest modifying your program to write the "Enter an age between 0 and 100" as the title of your input box and to remove all wait commands. Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
01-19-2016, 08:43 AM
(This post was last modified: 01-19-2016 08:48 AM by Carlos295pz.)
Wait isn't necesary
PHP Code: EXPORT p11_repeat_block() Viga C | TD | FB |
