Crash when using SORT function
01-22-2016, 11:46 AM
Hello
I have a problem with my HPPrime when I use the SORT function (not the CAS one) for certain lists. For instance, in HOME, when I enter
SORT({1,0,2,6,0,7,5,1,7,1,7})
The calculator crashes or displays strange characters.
I tried on a friend's calculator and had the same issue.
The firmware version is 2015 6 17 (8151) Rev A
On the emulator or iOS app, everything is working fine.
Do you have the problem ? Is this a bug in the current firmware ?
Thank you
01-22-2016, 12:05 PM
RE: Crash when using SORT function
Confirmed on the hardware device (only), especially noticeable when the list to be sorted is assigned to, say, the L0 reserved variable:
L0:={1,0,2,6,0,7,5,1,7,1,7};
SORT(L0); ==> Invalid Input followed by a group of Chinese characters.
-Dale-
01-22-2016, 04:13 PM
Have put it on the list for investigation. Thanks.
TW
