Possible bug in CAS?
01-25-2016, 08:14 PM
(This post was last modified: 01-25-2016 08:24 PM by MrMcChicken.)
I am doing some really basic calculations with complex numbers. After entering some random stuff I think I found a bug. If I enter: simplify(squareroot(x^2*y^2)) my Prime shows: -x*y. The emulator shows: abs(x)*abs (y) which is fine. Both run on the latest Firmware (8151). Can somebody confirm this issue? Greetings, MrMcChicken Edit: It happens too with simplify(squareroot((x^4*y^4)) = -x^2*y^2 |
01-25-2016, 09:24 PM
RE: Possible bug in CAS?
(01-25-2016 08:14 PM)MrMcChicken Wrote: If I enter: simplify(squareroot(x^2*y^2)) my Prime shows: -x*y.mine gives expected result : abs(x)*abs(y) primer |
01-25-2016, 09:58 PM
(01-25-2016 09:24 PM)primer Wrote: mine gives expected result : abs(x)*abs(y)mine also. Please, check the CAS Settings: I've Exact, Use β, Principal, not: Complex, use i, increasing. Simplify minimum... Salvo β«aLβ0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
01-25-2016, 11:46 PM
(This post was last modified: 01-25-2016 11:48 PM by primer.)
(01-25-2016 09:58 PM)salvomic Wrote: I've Exact, Use β, Principal, not: Complex, use i, increasing. Simplify minimum...same as you : three options on left are checked (exact...) and three ones on the right are not. Maybe you defined an "assume" ? or something like that ? I never remember where we can see existing assumes, but I think purge() cmd does remove all of them, check help before usage, just in case... Regards. primer |
01-26-2016, 09:13 AM
I found the source of the problem. If "use i" is checked i get -x*y as a result.
Why is this so? Is this a bug? Thanks for help so far. Greetings, MrMcChicken |
01-26-2016, 11:41 AM
If you set complex mode on ("use i" on the Prime), then sqrt(x^2) is no more equal to |x| and the system chooses one of the two complex square roots.
Should perhaps be somewhere in a FAQ. |
