show reserved variables on catalog and help
02-04-2016, 09:00 PM
please, in the "help topics" win to adhere a new item "reserved variables" also on catalog (submenu), is hard to remember the internal names when programming
DOM_INT DOM_FLOAT DOM_STRING DOM_SYMBOLIC DOM_FUNC DOM_LIST etc ... Code: .... local l; |
02-04-2016, 09:32 PM
RE: show reserved variables on catalog and help
I agree that adding the list of object type names to the Help system would be great. Meanwhile, using the 'type' command in CAS on a literal object of known type might be even faster than hunting for it in the Help system.
type(1) --> DOM_INT type("x") --> DOM_STRING type(x) --> DOM_IDENT etc. <0|ɸ|0> -Joe- |
02-04-2016, 10:51 PM
also the commands written in the input line, to display on the left side of history with the same nomenclature, not show them to uppercase, commands are case sensitive, this creates confusion
type ≠ TYPE CAS-MODE ________ type(4*i) ¯¯¯¯¯¯¯¯ => History TYPE(4*i) DOM_COMPLEX =( It should be viewed as type(4*i) DOM_COMPLEX =) |
02-06-2016, 06:10 AM
(02-04-2016 10:51 PM)compsystems Wrote: CAS-MODE A workaround: You can force it to display the correct case by turning off Textbook Display mode (Home Settings, page 2). <0|ɸ|0> -Joe- |
