Double integral problem
02-14-2016, 12:38 PM
Hello :-)
I am having trouble with a double integral on the HP Prime, that I believe I tried solving with a previous firmware (don't remember version), and now when I try it, the Prime returns:
"Error, Too many arguments: integrate"
I am doing this in CAS mode. Are there any settings than can cause this? See attached problem.
I am typing on the Prime: int(e^x^2,y,0,2*x,x,0,1)
Thanks.
02-14-2016, 12:56 PM
RE: Double integral problem
(02-14-2016 12:38 PM)Highdef Wrote:  I am typing on the Prime: int(e^x^2,y,0,2*x,x,0,1)
What about int(int(e^x^2,y,0,2*x),x,0,1) ?
Marcus von Cube
Wehrheim, Germany
http://www.mvcsys.de
http://wp34s.sf.net
02-14-2016, 01:33 PM (This post was last modified: 02-14-2016 01:34 PM by Highdef.)
That actually worked after getting this message:
Unable to check if antiderivative e^(x^2)*y has singular points for definite integration in [0,2*x]
Hitting enter after this gives me the solution.
Thank you very much! I will try to remeber this. Although I'm pretty sure I did't receive this message in an earlier version.
