Ans problem
02-15-2016, 11:39 AM
Ans problem
I'm a young french student, so please forgive my eventual grammatical errors. I would know if it's possible to remove the "Ans" when you press the "-" key. Indeed, it is very annoying to get an "Ans" when I just want to type, for example : "-2+1" -> I'm forced to remove the Ans every time... Any solution ? Thanks, periappi |
02-15-2016, 11:46 AM
RE: Ans problem
Use "+/-" key instead "-" key...
(This post was last modified: 02-15-2016 11:48 AM by Didier Lachieze.)
RE: Ans problem
Instead of pressing "-" , press "+/-" to enter a negative number: the key sequence [+/-] [2] [+] [1] will enter "-2+1"
[Ariel was faster than me ..] |
02-15-2016, 11:50 AM
RE: Ans problem
Awww ! Thank you very much, I was going to be mad otherwise ^^
