Bug in (8151)
02-18-2016, 12:06 AM
Bug in (8151)
Bad bug in copy/paste in the CAS wherein square roots can become mangled.
02-18-2016, 05:10 AM
RE: Bug in (8151)
I'm not able to duplicate it from typing in the lines I can see. Could you please post the complete equation you put into solve( ) in the first step?
Thanks!
TW
05-30-2016, 10:02 PM
RE: Bug in (8151)
(02-18-2016 05:10 AM)Tim Wessman Wrote:  I'm not able to duplicate it from typing in the lines I can see. Could you please post the complete equation you put into solve( ) in the first step?
Thanks!
I am no longer able to replicate it either, and I no longer have the original input, sorry.
05-31-2016, 12:29 PM (This post was last modified: 05-31-2016 12:58 PM by Fortin.)
RE: Bug in (8151)
This is likely due to NTHROOT being used instead of square root. In 8151, the parens around the 1/20 are not maintained during the copy. This is corrected in 10077.
Enter: 2 NTHROOT (1/20)
Then select the answer and press COPY.
In algebraic entry mode, you'll be able to see the different copy behaviors.
