Square Root Error in Home View
02-23-2016, 07:29 AM
When I use square root sign (√) on a complex number with both real and imaginary parts are negative, the answer in Home View is not correct. There is no problem in CAS View or using y^x (x=0.5) in Home View.
Am I doing something wrong or is it a bug?
Thanks a lot.
Attached File(s) Thumbnail(s)
02-23-2016, 05:18 PM
RE: Square Root Error in Home View
Looks like an issue, but I think has been resolved already. I suspect the ios version would do this correctly.
TW
05-01-2016, 01:56 AM
Hi Tim,
Confirmed the problem is solved with new firmware on the calculator, but not on the emulator.
Cheer!
05-01-2016, 04:45 AM (This post was last modified: 05-01-2016 05:00 AM by informach.)
Hi!, Killersing9588:
In my HP PRIME calculator, the Virtual PC emulator, for Windows, with ultimate version (10077), Wolfram Alpha y MathLab, the results, are ... (see, attachment's).
Kind Regards.
informach.
05-01-2016, 04:16 PM (This post was last modified: 05-01-2016 04:17 PM by Tim Wessman.)
(05-01-2016 01:56 AM)Killersing9588 Wrote:  Confirmed the problem is solved with new firmware on the calculator, but not on the emulator.
Definitely not matching what I am seeing here (returning 2-3i in all ways). In your emulator menu "Help->About hp Prime" are you seeing the latest version? Might an old one being run?
There should be no possibility for difference between the calc and emu here.
TW
05-02-2016, 04:30 AM
Thank you all!
It was the old version that I could not upgraded on Windows 7 only.
Killersing
