Gauss-Chebyshev Quadrature
02-24-2016, 03:57 PM (This post was last modified: 03-04-2021 11:17 PM by Namir.)
This is a program that calculates the area under a function using the Gauss-Chebyshev quadrature. The program prompts you for:
1. The lower limit of the integral, A.
2. The upper limit of the integral, B.
3. The number of points to use for the calculations, N. This is also the order of Chebyshev polynomial used in the calculations.
LBL E has the code for the function you want to integrate. Currently, the program integrates the function f(x)=1/x. The version of the quadrature implemented has equal weights of pi/N.
The memory map is:
R0 = A
R1 = B
R2 = N
R4 = T1 = (B-A)/2
R5 = T2 = (B+A)/2
R6 = T3 = pi/N/2
R7 = Sum = sum of f(T1*X+T2)
R8 = Y = COS((2i-1)*T3)
R9 = X = f(T1*X+T2)
1    LBL "GCQD"
2    LBL A
3    "A?"
4    PROMPT
5    STO 00
6    "B?"
7    PROMPT
8    STO 01
9    "N?"
10    PROMPT
11    STO 02
12    RCL 01
13    RCL 00
14    -
15    2
16    /
17    STO 04        # calculate T1
18    RCL 01
19    RCL 00
20    +
21    2
22    /
23    STO 05        # calculate T2
24    PI
25    RCL 02
26    /
27    2
28    /
29    STO 06        # calculate T3
30    RAD
31    0
32    STO 07        # Sum = 0
33    LBL 00        # start loop -----------------------
34    RCL 02
35    2
36    *
37    1
38    -
39    RCL 06
40    *
41    COS
42    STO 08        # calculate Y
43    RCL 04
44    *
45    RCL 05
46    +
47    STO 09        # calculate X
48    XEQ E        # calculate f(x)
49    1
50    STO- 02        # N = N - 1
51    RCL 08
52    X^2
53    -
54    SQRT
55    *
56    STO+ 07        # sum = sum + F * sqrt(1-Y*Y)
57    RCL 02
58    X#0?
59    GTO 00        # resume loop iterations
60    RCL 07
61    RCL 04
62    *
63    RCL 06
64    *
65    2
66    *
67    BEEP
68    RTN
69    LBL E        # subroutine for f(x)
70    1/X
71    RTN
