Right Arrow Character in Connectivity Kit?
02-28-2016, 08:05 PM
Hello again,
I use the HP Connectivity Kit to write and edit my HP Prime programs.
I recently had the opportunity to use the R->B (real-to-binary) command, and I typed in a minus sign and a greater than sign as I did in this sentence. When I transfer my program into my Prime, I get a syntax error in between the two characters. I can delete those two characters and the use the Chars key to get a right-arrow character (on page 10 of the Chars).
How can I type the right arrow character in the HP Connectivity Kit? If I have a program with many R->B commands, it will be tedious to edit them all after I transfer my program into the Prime.
I tried looking at my program in the Prime after I edited in the correct character, but in the HP Connectivity Kit window, it displays as '->' too, so I cannot copy the correct character over from the Prime into the HP Connectivity Kit.
Thanks in advance for any advice you may have.
smp
02-28-2016, 11:36 PM
RE: Right Arrow Character in Connectivity Kit?
One way is to use the Toolbox command for R→B() and place it on the emulator command line. From there, cut (cntrl-c) and paste, (contrl-v) where needed in your conn kit code. Alternatively, you can copy and paste just the arrow, which you can access from the [shift] [9] suite of chars.
-Dale-
03-01-2016, 12:22 AM
(02-28-2016 11:36 PM)DrD Wrote:  One way is to use the Toolbox command for R→B() and place it on the emulator command line. From there, cut (cntrl-c) and paste, (contrl-v) where needed in your conn kit code. Alternatively, you can copy and paste just the arrow, which you can access from the [shift] [9] suite of chars.
-Dale-
Thanks very much for your suggestions, Dale. Looks like I'm going to have to learn how to use the emulator. I have not used it at all so far, because I use my real Prime.
smp
