Help/user button to advanced option user/help
03-01-2016, 10:42 PM
So sometimes I like to eliminate pressing more buttons than is needed. And although I do like having help as a first class citizen, I'd like the option to artificially toggle something in the settings that made it so I could have user key the first class.
Tim do you think this is a reasonable request?
I'm not trying to change the layout of the keyboard, because I do use the help, but sometimes in in production mode.
-Luis-
03-02-2016, 06:34 AM
RE: Help/user button to advanced option user/help
I assume that you want, on a per key basis, to be able to remap the keyboard, including user keys in the map.
Is that what you are trying to do?
Cyrille
03-02-2016, 06:17 PM
I just want to be able to hit the user key without pressing shift first.
-Luis-
03-03-2016, 08:28 AM
(03-02-2016 06:17 PM)luisphysics Wrote:  I just want to be able to hit the user key without pressing shift first.
If I understand you want to press [help] key and it behave like [user] (shift-help)?
myself I only hit [user] very rarely : I only set user mode and I stay in this mode forever.
Do you so often enable/disable user mode ?
primer
