System menu Android apps
03-13-2016, 04:46 PM
Hello. i hid the "system menu" (Android prime) and I am unable to display it again. how can I do this?
03-13-2016, 05:31 PM (This post was last modified: 03-13-2016 09:42 PM by DrD.)
RE: System menu Android apps
You mean where you swipe your finger left to right on the display?
03-13-2016, 09:04 PM (This post was last modified: 03-13-2016 09:05 PM by Gilles.)
(03-13-2016 05:31 PM)DrD Wrote:  You mean where you swipe your finger right to left on the display?
I desactivated the menu in the top left position of the emulator and I want to display it again. it's the menu in wich you can choose the skin of the emulator on an Android device.
03-13-2016, 09:11 PM
Try swiping from left to right starting from off the left side of the screen. Then select Calculator -> Show Title when the menu appears.
03-14-2016, 06:20 PM
(03-13-2016 09:11 PM)Fortin Wrote:  Try swiping from left to right starting from off the left side of the screen. Then select Calculator -> Show Title when the menu appears.
Thanks a lot !
