Programmation Problem
03-21-2016, 05:43 PM
(This post was last modified: 03-21-2016 05:44 PM by periappi.)
I've got an issue I can't fix with my HP Prime : when I execute a program I got a syntax error concerning the "," (argument superator). The only way to fixe it is to use the "," key (between "()" and "Enter" keys) and it puts a ";" symbol... Do you have any idea to fix it ? Thank you, and sorry for my english periappi PS : Example of error : "LOCAL A=0, B=0, C=0.........." "CHOOSE(A, "Choisissez un thème"......" PS 2 : But I haven't this problem with my emulator, the program works. |
03-21-2016, 07:49 PM
RE: Programmation Problem
I suspect that pragma may help to align the separators with your code's expectations:
http://www.thecalculatorstore.com/Calcul...r-settings |
03-21-2016, 08:53 PM
(03-21-2016 07:49 PM)Fortin Wrote: I suspect that pragma may help to align the separators with your code's expectations: Thanks ! It works, and thank you for your quick reply ! |
