Ci and Si without arguments [SOLVED]
03-27-2016, 02:22 PM
(This post was last modified: 11-01-2018 10:53 AM by JMB.)
I have found the following behavior of Ci and Si without arguments:
In HOME: Ci() returns: -Inf Si() returns: [] In CAS: Ci() returns: -∞ Si() returns: [] So, it seems that Ci() is using 0 as the default argument, but does anyone know the meaning of [] for Si() ? UPDATE. I have found that Ei also has an odd behavior when no arguments are supplied: In HOME and CAS: Ei() returns: Ei |
11-01-2018, 10:53 AM
RE: Ci and Si without arguments
In the new FW version 2.1.14181 (2018 10 16) all three functions Ci(), Si() and Ei(), return [] both in HOME and CAS. This looks more coherent than the previous behavior.
Josep Mollera. HP PRIME, HW: C, SW: 2.2.15157 (2024-09-01). |
