HP35s bug ?
04-04-2016, 10:11 PM
HP35s bug ?
Could you confirm the following bug : Tape this (stupid) program : PRGM TOP 0001 1 0002 2 0003 3 0004 4 0005 RTN Now, if you exit PRGM and push the value 10 (for instance) in the stack, you will get 10.0000000007 If the program is : PRGM TOP 0001 1 0002 2 0003 3 0004 4 0005 5 0006 RTN Now, you can't even enter 10 (you will get 1?) Did i miss something ? Thank you, Philippe |
04-04-2016, 10:33 PM
RE: HP35s bug ? | |||
04-05-2016, 05:38 AM
RE: HP35s bug ?
Philippe,
was your program memory and stack empty when entering this program? Would you mind listing the exact series of keystrokes needed to reproduce the bug? Best regards, Thomas |
04-05-2016, 09:49 PM
RE: HP35s bug ?
Thanks to Voldemar for trying. @thomas : i reproduce this behaviour each time. 1) I clear all (Blue arrow CLEAR 3 Yes Enter) 2) then i type the program : blue arrow PRGM 1 ENTER 2 ENTER 3 ENTER 4 ENTER yellow arrow RTN C 3) back to the stack, i type 10 ENTER Then the stack show 10.00000007 10.00000007 If i edit the program and remove the line containing "4", then all works Now, if : 1) I clear all (Blue arrow CLEAR 3 Yes Enter) 2) blue arrow PRGM 1 ENTER 2 ENTER 3 ENTER 4 ENTER 5 ENTER yellow arrow RTN C 3) back to the stack, i type 10 I get : 1? If i type the ENTER key, i have a syntax error More info : a) if i type 1. (digit "1" + a dot ".") I get : 1n ("1n") Thanks for your help, Philipe |
04-06-2016, 11:09 AM
RE: HP35s bug ?
(04-05-2016 09:49 PM)Philippe Wrote: @thomas :Thank you very much for your effort! That maybe explains deviating results: I cannot clear all as I have some programs, equations and data I want to keep. You may already know the 35s bug list. Not sure if it is still maintained, I seem to remember there was another bug connected to the stack found a couple of months ago, but it isn't listed here. Best regards, Thomas |
04-06-2016, 12:29 PM
(This post was last modified: 04-06-2016 12:31 PM by jebem.)
RE: HP35s bug ?
Nope, all is working fine on my two different HP-35S machines when typing your two examples.
I get 10.000 all the time, and if I do a Show, it will display the full number with all trailing zeros. Definitely is not a bug. You have a faulty machine. (04-05-2016 09:49 PM)Philippe Wrote: Hi, Jose Mesquita RadioMuseum.org member |
04-06-2016, 11:27 PM
RE: HP35s bug ?
I do maintain the bug list even though I don't have a 35S any more.
I skim a lot of postings here and can easily miss things. - Pauli |
04-07-2016, 06:23 AM
RE: HP35s bug ?
Well, thanks all for your help
As Jebem said, i'm pretty sure that I have a faulty machine (@Thomas, the "clear all" command is in fact not necessary. I used it just to clearly show the problem) Thus,I will not report this behavior as a bug in Paul's list If someone wants to see a video of the problem, I can post it (in my Dropbox ?) Thanks to all Philippe |
04-07-2016, 09:04 AM
RE: HP35s bug ?
I would like to see it.
Thanks Marcio |
04-07-2016, 09:30 AM
RE: HP35s bug ?
Me too!
04-07-2016, 10:40 AM
RE: HP35s bug ?
Here is a temporary Dropbox link :
https://db.tt/QJTdco9r I will appreciate some feedback ! Thanks, Philippe |
04-07-2016, 10:48 AM
RE: HP35s bug ?
Nasty!
If it's under warranty, you should ask for a replacement. This machine seems to be faulty and cannot and should not be trusted. |
04-07-2016, 11:08 AM
(This post was last modified: 04-07-2016 11:12 AM by jebem.)
RE: HP35s bug ?
(04-07-2016 10:40 AM)Philippe Wrote: Here is a temporary Dropbox link : That's very interesting behavior, but again, my two machines, made in different years, do NOT have this behavior. One if from 2007 week 28 (S/N CNA 72800051) The other is from 2012 week 12 (S/N CNA21200BH) Anyhow, HP would never release a machine with such a obvious misbehavior. The so called 35S bugs took years to be found. If this one was a bug, I'm sure it would be found in the very first day of testing! What is the S/N of yours? Jose Mesquita RadioMuseum.org member |
04-07-2016, 11:21 AM
04-07-2016, 11:33 AM
RE: HP35s bug ?
(04-07-2016 11:21 AM)Paul Dale Wrote:(04-07-2016 11:08 AM)jebem Wrote: The so called 35S bugs took years to be found. Sorry, Paul, my mistake. I'm not a native English speaker, so you have to excuse me. I meant that some bugs took years to be found. Jose Mesquita RadioMuseum.org member |
04-07-2016, 09:42 PM
RE: HP35s bug ?
@Marcio, yes it is under warranty and I will ask asap for a replacement. @Jebem, the S/N is CNA54614CH (means ?) Thanks again ! Philippe |
04-07-2016, 11:47 PM
04-08-2016, 12:37 AM
RE: HP35s bug ?
Very good idea !
Unfortunately, this has no effect... (Turn off the calculator without resetting anything) I also removed the batteries, this time it produces a "memory clear", nothing more... Definitely a faulty machine. Thanks, Philippe |
