Help: Port prg to Home Mode( Minor linear_algebra)
02-02-2014, 11:43 PM (This post was last modified: 02-10-2014 02:09 PM by compsystems.)
http://en.wikipedia.org/wiki/Minor_(linear_algebra)
ENTRY LINE EDITON Sad
minor_CAS0(m1):=
begin
  return(seq(seq(det(delRow(delCol(m1,j),I)),j,1,colDim(m1)),I,1,rowDim(m1)))​​;
end;
[enter]
then
minor_CAS0([[1,2,3],[4,5,6],[7,8,9]]); [enter] returns
[[-3,-6,-3],
[-6,-12,-6],
[-3,-6,-3]] OK Smile
but HOME MODE
PRG EDITOR
EXPORT minor_HOME0(m1)
begin
  local out;
  local j:="jj", ii:="ii"; // trick =(
  out := seq(seq(det(delRow(delCol(m1,j),ii)),j,1,colDim(m1)),ii,1,rowDim(m1));
  return(out);
end;
minorHOME([[1,2,3],[4,5,6],[7,8,9]]); [enter] returns "Error: Bad Argument Type" ????
02-03-2014, 05:38 AM
RE: Help HOME PRG (Minor linear_algebra)
Why are you defining j and ii as strings? Also, the help for DELCOL() and DELROW() suggest that they modify the matrix itself, so that subsequent references to the matrix are actually references to the the modified version.
To see this for yourself:
M1:=[[1,2],[3,4]];
DELCOL(M1,1);
M1;
My guess is that in CAS mode the dummy variable somehow protects its contents to prevent DELCOL() and DELROW() from modifying the matrix. Either that, or it is a bug.
The commands you should probably be using instead: delcols() and delrows() -- these do not alter the matrix.
EXPORT MINOR(m)
  LOCAL n:=dim(m),s;
  s:=n(1)*n(2);
  n:=n(1);
  MAKELIST(det(delcols(delrows(m,((I-1) MOD n)+1),IP((I-1)/n)+1)),I,1,s);
You can easily change this to use seq() if you prefer. Just don't confuse a sequence with a matrix even if they both use the same delimiters.
Graph 3D | QPI | SolveSys
02-03-2014, 03:06 PM (This post was last modified: 02-03-2014 03:44 PM by compsystems.)
sorry for my bad English
The version in CAS mode works fine, but not in HOME mode =(, but as there is not a program editor for cas mode my calculator this underutilized.
Han: Why are you defining j and ii as strings?
I try to do the trick you discussed in another topic.
http://www.hpmuseum.org/forum/thread-538.html
export convolution1(v1,v2)
begin
  local p1,p2,c,var:="x_";
  purge(var);
  p1:=poly2symb(v1,var);
  p2:=poly2symb(v2,var);
  c:=symb2poly(simplify(p1*p2),var);
  return(c);
end
Han: Just don't confuse a sequence with a matrix even if they both use the same delimiters.
the seq command generates a one-dimensional array, and seq (seq generates a two-dimensional array
seq(x²,x,1,3); enter returns
[1,4,9]; TYPE(Ans); returns 4 (Matrix 1x3) best vector =)
seq(seq(x²,x,1,3),x,1,2); enter returns
[[1,1,1],
[4,4,4]]; TYPE(Ans); returns 4 (Matrix 2x3)
Using the seq cmd, number of instructions is reduced =)
minorCAS2(m1):=
RETURN(seq(seq(det(delRow(delCol(m1,j),I)),j,1,colDim(m1)),I,1,rowDim(m1)));  // i == unit imaginary =(
minorCAS2([[1,2,3],[4,5,6],[7,8,9]]); [enter] returns
[[-3,-6, -3]
[-6,-12,-6]
[-3,-6, -3]] OK Smile
versus your code
EXPORT MINOR(m)
  LOCAL n:=dim(m),s;
  s:=n(1)*n(2);
  n:=n(1);
MINOR([[1,2,3],[4,5,6],[7,8,9]]); [enter] returns {-3,-6,-3,-6,-12,-6,-3,-6,-3} LIST
http://www.maplesoft.com/support/help/Ma...ebra/Minor
02-03-2014, 07:22 PM (This post was last modified: 02-04-2014 03:27 AM by Han.)
Quote:Using the seq cmd, number of instructions is reduced =)
That may be true, but sometimes it is beneficial to separate your commands. For example, using coldim() inside the seq() command means coldim() is computed repeatedly -- which is unnecessary, and slow if you have a much larger matrix. If you precompute the dimensions, then the seq() command would only be reading a value as opposed to calculating it every iteration. Secondly, separating the commands makes debugging much easier.
As for list vs matrix, try:
EXPORT MINOR(m)
  LOCAL n=dim(m),n1,n2;
  n1:=n(1); n2:=n(2);
  MAKEMAT(det(delcols(delrows(m,I),J)),n1,n2);
02-09-2014, 03:15 PM (This post was last modified: 02-09-2014 03:29 PM by compsystems.)
export MINOR_HOME1(m)
begin
   local n;
   n:=dim(m);
   return(makemat(det(delcols(delrows(m,I),J)),n(1),n(2)));
end;
MINOR_HOME1([[1,2,3],[4,5,6],[7,8,9]]); [enter] returns
[[-3,-6, -3]
[-6,-12,-6]
[-3,-6, -3]] OK
MINOR_CAS1(m):=
begin
   local n;
   n:=dim(m);
end
MINOR_CAS1([[1,2,3],[4,5,6],[7,8,9]]); [enter] returns ???
{{"Error: Bad Argument Type","Error: Bad Argument Type","Error: Bad Argument Type"},
{"Error: Bad Argument Type","Error: Bad Argument Type","Error: Bad Argument Type"}}
MINOR_CAS0(m1):=
begin
 return(seq(seq(det(delRow(delCol(m1,j),I)),j,1,colDim(m1)),I,1,rowDim(m1)))​;
end;
MINOR_CAS0([[1,2,3],[4,5,6],[7,8,9]]); [enter] returns
[[-3,-6, -3]
[-6,-12,-6]
[-3,-6, -3]] OK
02-09-2014, 03:26 PM (This post was last modified: 02-09-2014 03:29 PM by Han.)
MAKEMAT() and makemat() are two different commands.
MAKEMAT(expr, m, n): MAKEMAT(I^2+J, 3, 5);
makemat(func, m, n): makemat( (x,y)->x^2+y, 3, 5);
Is there any reason to insist on using a CAS program instead of a regular program?
02-09-2014, 03:55 PM (This post was last modified: 02-09-2014 09:25 PM by compsystems.)
now with MAKEMAT on CAS MODE fail Why?
MINOR_CAS2(m):=
 begin
    local n;
    n:=dim(m);
    return(MAKEMAT(det(delcols(delrows(m,I),J)),n(1),n(2)));
 end
MINOR_CAS2([[1,2,3],[4,5,6],[7,8,9]]); [enter] returns
"Error: Bad Argument Type ??
Quote:Han: MAKEMAT() and makemat() are two different commands.
>> On HOME mode MAKEMAT() and makemat() are equal
I: HOME MODE
INDEX = (1,1) for MAKEMAT or makemat or makeMat or or any combination of uppercase and lowercase
MAKEMAT(I^2+J,3,5); // HOME MODE =>
[[2,3,4,5,6],
[5,6,7,8,9],
[10,11,12,13,14]] OK
makemat(I^2+J,3,5); makeMat(I^2+J,3,5); => MAKEMAT(I^2+J,3,5); // HOME MODE =>
[[2,3,4,5,6],
[5,6,7,8,9],
INDEX = (1,1)
step1: I=1, J=1,..,5
1^2+1=2, 1^2+2=3, 1^2+3=4, 1^2+4=5, 1^2+5=6 // ok
step2: I=2, J=1,..,5
2^2+1=5, 2^2+2=6, 2^2+3=7, 2^2+4=8, 2^2+5=9 // ok
step3: I=3, J=1,..,5
3^2+1=10, 3^2+2=11, 3^2+3=12, 3^2+4=13, 3^2+5=14 // ok
MAKEMAT((I,J)->I²+J,3,5); or makemat((I,J)->I²+J,3,5); "Error: Syntax Error"
On CAS mode MAKEMAT() and makemat() are not equal =) Support catalog says nothing about this =(
Quote:Han: Is there any reason to insist on using a CAS program instead of a regular program?
Muchas, una de ellas es que algunos comandos se comportan diferente. entonces se puede aprovechar esta característica dentro de un programa, otra permite una mas fácil manipulación de expresiones simbolicas
MAKEMAT en CAS MODE opera en índice (0,0) =)
INDEX = (0,0) for makemat and INDEX = (1,1) for MAKEMAT
makemat( (I,J)->I²+J, 3,5); // CAS MODE
[[0,1,2,3,4],
[1,2,3,4,5],
[4,5,6,7,8]] OK
step1: I=0 J=0,..,4
0^2+0=0, 0^2+1=1, 0^2+2=2, 0^2+3=3, 0^2+4=4 // ok
step2: I=1, J=0,..,4
1^2+0=1, 1^2+1=2, 1^2+2=3, 1^2+3=4, 1^2+5=6 // ok
step3: I=2, J=0,..,4
2^2+0=4, 2^2+1=5, 2^2+2=6, 2^2+3=7, 2^2+4=8 // ok
MAKEMAT(I²+J,3,5); // CAS MODE
[[2,3,4,5,6],
[5,6,7,8,9],
BUT
MAKEMAT((I,J)->I²+J,3,5); // CAS MODE
Bug because should return only the right evaluation of the function
[[(1,1)->1²+1,(1,2)->1²+2,(1,3)->1²+3,(1,4)->1²+4,(1,5)->1²+5],
[(2,1)->2²+1,(2,2)->2²+2,(2,3)->2²+3,(2,4)->2²+4,(2,5)->2²+5],
[(3,1)->3²+1,(3,2)->3²+2,(3,3)->3²+3,(3,4)->3²+4,(3,5)->3²+5]] =(
F1(I,J):=I^2+J; returns F1:=(I,J)->I²+J => (I,J)->I²+J
makemat(F1(I,J),3,5) // CAS MODE
or MAKEMAT(F1(I,J),3,5) // CAS MODE
Not operate, why? BUG?
"makemat(F1(I,J),3,5) Error: Bad Argument Value" ...
makeMat(I²+J,3,5);
[[0,0,0,0,0],
[0,0,0,0,0],
[0,0,0,0,0]] ???
makeMat((I,J)->I²+J,3,5);
"Error: Unmatch control word" ??
Han can you port the following code to HOME MODE
 // Code on CAS MODE OK, HOME MODE =(
collectPolTerms_CAS0( Poly, Var ):=
    RETURN( sum( coeff( Poly, Var ) .* seq( Var^k, k, degree( Poly, Var ), 0, 1 ) ));
with simplify NONE (CAS Settings),
collectPolTerms_CAS0(((-3*a*x²+7*a*x^1-2*a-3*b*x²+7*b*x^1-2*b+3*x^3-7*x²+2*x^1)/3),x); [ENTER} returns
x^3+((-3*a-3*b-7)/3)*x²+((7*a+7*b+2)/3)*x+(-2*a-2*b)/3 OK
Thanks
02-09-2014, 05:35 PM (This post was last modified: 02-09-2014 05:37 PM by Han.)
(02-09-2014 03:55 PM)compsystems Wrote:  >> On HOME mode MAKEMAT() and makemat() are equal
That is because Home view does not distinguish upper case from lower case. Home view is not aware of CAS commands (generally speaking; there are a few CAS commands that still work in Home because they have been implemented for Home). CAS commands will sometimes work (in lower case) but generally require the CAS.command() format. So MAKEMAT() and makemat() are the same in Home, but CAS.makemat() is different.
Quote:On CAS mode MAKEMAT() and makemat() are not equal =)
Correct.
Quote:Support catalog says nothing about this =(
Unfortunately, the catalog is missing a LOT of information.
Quote:MAKEMAT en CAS MODE opera en índice (0,0) =)
INDEX = (0,0) for make mat
MAKEMAT(I²+J,3,5);
[[2,3,4,5,6],
[5,6,7,8,9],
BUT
MAKEMAT((I,J)->I²+J,3,5); Bug because should return only the right evaluation of the function
Don't mix commands and syntax. You are using MAKEMAT() but you are trying to incorporate the syntax of the other command: makemat(). MAKEMAT() is working exactly as you told it to. When you use the (I,J)->I^2+J syntax, MAKEMAT() -- because it is NOT a CAS command -- has no idea about the meaning of (var)->expr because that is a CAS syntax. Instead, MAKEMAT treats (I,J)->I^2+J as an expression and substitutes values of I and J in, and simplifies as best it can.
Quote:F1(I,J):=I^2+J
makemat(F1(I,J),3,5) or MAKEMAT(F1(I,J),3,5)
Not operate, why?
Because the first argument of makemat() -- which is a CAS command -- requires a function. So either use F1 by itself, or use (I,J)->I^2+J. When you used F1(I,J), then this is an evaluation of a function, which produces a expression.
Quote:makeMat(I²+J,3,5);
[[0,0,0,0,0],
[0,0,0,0,0],
[0,0,0,0,0]] ???
Here I and J are constants -- 0. The command line interpreted "makeMat" as "makemat" so that you are just requesting a 3x5 matrix with 0 as the entry.
There is nothing required for porting. If you want to use that command in Home, just put your arguments as strings. So in Home view, do:
collectPolTerms_CAS0("((-3*a*x²+7*a*x^1-2*a-3*b*x²+7*b*x^1-2*b+3*x^3-7*x²+2*x^1)/3)","x")
02-09-2014, 08:26 PM (This post was last modified: 02-09-2014 09:22 PM by compsystems.)
abstract
for HOME MODE
MAKEMAT(expresion/expresion(I,J), m, n) or makemat(expresion/expresion(I,J), m, n) or makeMAT(expresion/expresion(I,J), m, n) with INITIAL INDEX (I=1,J=1)
example with expresion
MAKEMAT(X+2, 3, 5); or makeMat(X+2, 3, 5); =>
[[2,2,2,2,2],
[2,2,2,2,2],
[2,2,2,2,2]] OK, with the current value of X (by default 0)
MAKEMAT(X^2+Y, 3, 5); or makeMat(X^2+Y, 3, 5); =>
[[0,0,0,0,0],
[0,0,0,0,0],
[0,0,0,0,0]] OK, with the current value of X, Y (by default 0)
with expresion(I,J)
MAKEMAT(I^2+J, 3, 5); or makeMat(I^2+J, 3, 5); =>
[[2,3,4,5,6],
[5,6,7,8,9],
with function
MAKEMAT((I,J)->I²+J,3,5); or makemat((I,J)->I²+J,3,5); "Error: Syntax Error" OK
for CAS MODE
with uppercase and expresion(I,J)
MAKEMAT(I^2+J, 3, 5); // INITIAL INDEX (I=0,J=0)
[[2,3,4,5,6],
[5,6,7,8,9],
another expresion
MAKEMAT(Ii^2+Ee, 3, 5);
[[Ii²+Ee,Ii²+Ee,Ii²+Ee,Ii²+Ee,Ii²+Ee],
[Ii²+Ee,Ii²+Ee,Ii²+Ee,Ii²+Ee,Ii²+Ee]] OK
lowercase
makemat( function(I,J), m, n) with INITIAL INDEX (I=1,J=1)
example
makemat( (I,J)->I²+J, 3,5); =>
[[0,1,2,3,4],
[1,2,3,4,5],
[4,5,6,7,8]] OK
makemat((X,Y)->X²+Y,3,5); =>
[[0,1,2,3,4],
[1,2,3,4,5],
[4,5,6,7,8]] OK
Han: interpreted "makeMat" as "makemat"
not operate as you say
makeMat((I,J)->I²+J,3,5); => "Error: Unmatch control word" ??
with expresión
makemat(Ii^2+Ee, 3, 5);
makemat(I^2+J, 3, 5);
[[0,0,0,0,0],
[0,0,0,0,0],
[0,0,0,0,0]] OK // I and J with the current value of I, J (default 0)
Quote:Han: There is nothing required for porting.
// port for HOME MODE
EXPORT collectPolTerms_HOME0( Poly, Var )
help "Error Syntax on k" =(
02-10-2014, 03:53 AM (This post was last modified: 02-10-2014 03:54 AM by Han.)
(02-09-2014 08:26 PM)compsystems Wrote:  abstract
for HOME MODE
There is only one command in Home mode no matter how you type it, it will get parsed as MAKEMAT(). If you want to use the CAS command in Home, the only way to do so is use CAS.makemat().
This is incorrect. MAKEMAT() is the non-CAS command and its index starts at 1 for I and J.
Incorrect. The index for the CAS command makemat() starts at 0.
This is a mistake on my part (a typo). "makeMat" is parsed as "MAKEMAT." However, due to the fact that we are typing this from the CAS view, the command line tries to parse it in a way that Home would expect (because MAKEMAT is not a CAS command). Thus, all variables within the argument are resolved first. If they cannot be resolved, this generates an error. (This is either a bug, or a poor design choice.) Anyway, the code
cannot work for two reasons:
1. makeMat is parsed as MAKEMAT (so that the functional expression is invalid)
2. in an attempt to resolve the variables in the expression (I,J)->I^2+J would result in an invalid argument
I will have to look into this more carefully as I overlooked the variable k the first time.
User(s) browsing this thread:
