WP 34S Programming Adapter Plug Parts - FS
02-04-2014, 03:54 AM (This post was last modified: 05-06-2014 03:40 PM by Dave Frederickson.)
I have parts left over from making an adapter plug for WP 34S programming adapters. The parts are for sale at my cost. Here's the finished plug:
[Image: Pogo+Plug+.jpg]
[Image: Pogo+Plug+2+.jpg]
[Image: Parts.JPG]
Part List
1 - 2mm IDC ribbon cable assembly, 12 inches long
11 - Spear point pogo pins type PA50-B
1 - 2mm machined socket strip in case you'd like to make Katie's version
1 - Brass strip, aprox 0.25 x 2 x 0.16 inches to make a clip or you can use a piece of tin can
You'll need a small piece of double-sided foam tape to attach the clip.
No soldering is required to assemble the plug.
A RS232-Serial or USB-Serial like Harald's adapter is required to make a complete programming cable
Details can be found here [Forum Thread] and here [Katie Wasserman's Article]
$5.50 USD for the parts. U.S. First-Class Mail included.
Update: All gone.
02-05-2014, 12:28 PM
RE: WP 34S Programming Adapter Plug Parts - FS
Dave
YGM
Roger
05-16-2014, 11:49 AM
Thank You, Dave!
I just got my package in the mail with your pogo kit.
