error in emulator
04-23-2016, 02:24 AM
error in emulator
I entered 3*sqrt3*sqrt3 and got an answer of 9.00000000001
does the real Prime make this same funny answer?
04-23-2016, 03:10 AM
RE: error in emulator
(04-23-2016 02:24 AM)SalivationArmy Wrote:  I entered 3*sqrt3*sqrt3 and got an answer of 9.00000000001
This funny answer is find in Home by me. In CAS, it make the correct answer: 9.
Remember the Home mode give an approximated result, while CAS don't. The definition of Home mode can be an explanation to this funny result.
04-23-2016, 04:20 AM
http://www.hpmuseum.org/forum/thread-5575.html
http://www.hpmuseum.org/forum/thread-5329.html
04-23-2016, 05:49 AM (This post was last modified: 04-23-2016 06:18 AM by SalivationArmy.)
I understand now.
Instead of logically multiplying 3 x 3 and placing the result under the sqrt like a human brain would, it's calculating the result of each of the sqrt3 to 10 or so digits the rounding off, which is NOT a perfect result, then working the problem.
human:
3* sqrt3 *sqrt3 =
3 * sqrt9 =
3 * 3 =
9
Honest calculator:
3* sqrt3 *sqrt3 =
3 * 1.73205080757 * 1.73205080757 =
9.00000000001
(The bolded digits are rounded off)
Nasa calculated the square root of three out to 10 million digits, you can imagine it a mess of a number. Here's the first 500 digits:
1.732050807568877293527446341505872366942805253810380628055806979451933016908800​0370811461867572485756
75626141415406703029969945094998952478811655512094373648528093231902305582067974​82010108467492326501
53123432669033228866506722546689218379712270471316603678615880190499865373798593​89467650347506576050
75661834812960610094760218719032508314582952395983299778982450828871446383291734​72241639845878553976
67958063818353666110843173780894378316102088305524901670023520711144288695990956​36579708716849807289
04-23-2016, 06:10 AM
This answer is not funny, it's simply correct.
Like any other finite-precision calculator the Prime does not return sqrt 3. It returns a value that matches sqrt 3 in its first twelve digits, i.e. 1,73205080757.
But that's not sqrt 3 = 1,7320508075688772935274463415... etc. etc.
Now the Prime gives the exact answer based on this approximation of sqrt 3:
3 x 1,73205080757 = 5,19615242271
5,19615242271 x 1,73205080757 = 9,0000000000116675...
Which, rounded to 12 digits, is the result you see (9,00000000001).
Try sqrt 7 x sqrt 7 or sqrt 8 x sqrt 8. If your calculator works correctly you should not get 7 and 8 but 6,99999999998 and 8,00000000002.
Dieter
