Evaluate Function variable in RPN mode?
02-04-2014, 12:58 PM
If I store a function like (X-4)/X in F1, then I can evaluate F1 at different values of X in Textbook mode very easily. For example, I just type F1(0) or F1(3) to evaluate it at X=0 or X=3.
But in RPN mode I have to enter a value into variable X, then recall F1 and EVAL it. Is there an easier way? Since F0-F9 are functions in X, it would easier if they just took their argument from the stack like the built in functions.
Thanks,
Dave
02-04-2014, 01:33 PM
RE: Evaluate Function variable in RPN mode?
F1 behaves like a program. In RPN, commands are typed as: COMMAND(n) where the n designates the number of arguments for COMMAND. Suppose F1(X):=2*X^2-4. If you type 9 ENTER F1(1) then it executes F1 as a program using 1 argument, namely the 9 on the stack. Unlike the other commands where one can leave off the "(1)" in the case of a single argument, you must explicitly specify "F1(1)" (from what I can tell). Typing F1 by itself recalls the formula for F1 as I'm sure you already found out.
Graph 3D | QPI | SolveSys
02-04-2014, 02:14 PM
The reason for this is that you have a function that can either take no arguments (in which case it recalls itself) or take 1 argument and evaluate through the function.
TW
02-04-2014, 02:27 PM
Thank you Han and Tim! I had a vague recollection about the parens but didn't remember that you must include the argument count.
Thanks,
Dave
