FW 10077 and RECT_P (issue)
04-24-2016, 11:18 AM (This post was last modified: 04-24-2016 02:22 PM by komame.)
I noticed a strange issue in the RECT_P (FW 10077).
Try this code:
EXPORT RECT_P_TEST_ALPHA()
  local c = #FF0000;
  RECT_P(G0,0);
  TEXTOUT_P("TRANSPARENCY 0",40,0,4,#FFFFFF);
  RECT_P(40,0,200,19,{c,0}); // should be opaque
  TEXTOUT_P("TRANSPARENCY 50",40,40,4,#FFFFFF);
  RECT_P(40,40,200,59,{c,50});
  TEXTOUT_P("TRANSPARENCY 100",40,80,4,#FFFFFF);
  RECT_P(40,80,200,99,{c,100});
  TEXTOUT_P("TRANSPARENCY 150",40,120,4,#FFFFFF);
  RECT_P(40,120,200,139,{c,150});
  TEXTOUT_P("TRANSPARENCY 200",40,160,4,#FFFFFF);
  RECT_P(40,160,200,179,{c,200});
  TEXTOUT_P("TRANSPARENCY 255",40,200,4,#FFFFFF);
  RECT_P(40,200,200,219,{c,255}); // should be transparent
  WAIT();
The middle transparency values are displayed properly, but the first text shouldn't be visible because of black ractange (transparency = 0) covers the text and the last one should be visible (255 = full transparency fo rectangle), but it did'nt displays this way.
Edit:
I think also there is a inconsistency with alpha parameter for BLIT and RECT, because in BLIT for apha = 0 means full transparency but for RECT alpha = 0 means full opaque.
Piotr Kowalewski
Radioactive Wastes - game for HP Prime
04-25-2016, 05:32 AM
RE: FW 10077 and RECT_P (issue)
hello,
Thanks, will place this in the list.
Cyrille
11-08-2017, 12:15 AM
Very happy with the alpha theme has finally been corrected
Viga C | TD | FB
