Little glitches in Backups
04-27-2016, 04:10 PM
1) If you open the memory/backups UI and there is no early backups, and you create backups from that state, it does not show the options below for the backup:
![]() 2) No confirmation when the backup name is already used. Is the backup overwritten? My website: ried.cl |
04-27-2016, 06:04 PM
(This post was last modified: 04-27-2016 09:32 PM by Spybot.)
RE: Little glitches in Backups
Hi!
[(1) If you open the memory/backups UI and there is no early backups, and you create backups from that state, it does not show the options below for the backup:] In my physical calculator after I created a new backup... it doesn't show any options (in the soft menu) "right away" other than [New], but if I exit that window and come back again to the same window, now it does show [Restore][Delete][New][ ][ ][ ] menu options for whatever backups I have at the moment. Anyway I agree with you, that it is supposed to show those menus as soon as you create the backup. [(2) No confirmation when the backup name is already used. Is the backup overwritten?] this one you're right! If I have one backup, and I attempt to create another one without changing the name, in fact it seems like the old backup is overwritten with out a confirmation message. Spybot. |
04-28-2016, 03:18 AM
Yes, confirmed the two observations.
Success is the ability to go from one failure to the next without any loss of enthusiasm. View PNG/JPG in your Prime |
