EXPORT vs AVars()
05-03-2016, 12:54 AM
(This post was last modified: 05-03-2016 01:11 AM by jgreenb2.)
EXPORT vs AVars()
I've started to fix up some old programs to be compatible with the latest firmware releases. A while back the function AVars() was added. However, I'm confused about what this actually does and how to best use it.
In my app I can declare: Code: EXPORT foo:="foo"; and this will create a variable that is scoped to the app. In other words I can access it from Home by either: Code: MyApp.foo or simply Code: foo if my current app is "MyApp". Alternatively I can write: Code:
But the result seems the same. Why bother with AVars at all? |
05-03-2016, 04:49 AM
RE: EXPORT vs AVars()
AVars has a couple of advantages over EXPORT: - It does not require one to 'program'. - AVars persist over a program recompile and an app being sent to a remote calculator - AVars do not require the program to be loaded and compiled to be 'live'. EXPORT has different advantages: - In a program, you know that the variable exist and you can create/initialize it using a smla syntax - global program variable can be hidden from users (ie, not exported) - program global are slightly faster than AVars Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
05-03-2016, 10:18 AM
(05-03-2016 04:49 AM)cyrille de brébisson Wrote: Hello, Cyrille, Thanks. That's very clear. -- Jeff |
