Bug in EIGENVV in combination with built-in matrices M0..M9 in 10077
05-04-2016, 10:24 PM
(This post was last modified: 05-04-2016 10:41 PM by Arno K.)
Today I came across the task of getting a matrix simplified with different ways to perform, one was M= [[2,0,0,0],[2,2,0,0],[1,-1,2,-1],[0,1,0,2]], a Schur decomposition was to be done and this is provided by the Prime.
As I want to check out the Prime's capabilities I tried to get the eigenvalues, easily computed by hand, all are 2, the Prime gives a warning ( "Low accuracy" ) and using EIGENVAL(M3), provides 4 values which can be rounded to 2. Then I tried EIGENVV(M3) and the physical prime simply restarted, the PC-emulator halted (both latest firmware) and the Android-app (8151) crashed, too. Recalling M3 and EIGENVV(Ans) delivers: "Not invertible error: Bad Argument Value", contrary to Wolfram, saying [0,0,1,0] is an eigenvector and that is correct. Arno |
05-05-2016, 05:08 AM
RE: Bug in EIGENVV in combination with built-in matrices M0..M9 in 10077
Crashed again because the Prime does not have exceptions, it returns a "not invertible error" on Xcas (this is expected because the matrix is not diagonalizable, therefore numeric diagonalization will fail while exact diagonalization works).
05-06-2016, 06:32 PM
(This post was last modified: 05-06-2016 06:32 PM by compsystems.)
MATHEMATICA
https://www.wolframalpha.com/input/?i=EI...0,2%5D%5D) [2,2,2] TI68K EIGVL([[2,0,0,0],[2,2,0,0],[1,-1,2,-1],[0,1,0,2]]) [enter] [2,2,2] hpprime EIGENVAL([[2,0,0,0],[2,2,0,0],[1,-1,2,-1],[0,1,0,2]]) [enter] "Low accuracy" then [2.00058131764,1.99961844696, 2.00018411644, 1.99961611895] https://www.wolframalpha.com/input/?i=EI...0,2%5D%5D) Prime does not have exceptions??? So, why not incorporated? |
05-06-2016, 07:03 PM
You can get exact eigenvalues inside the CAS, even more jordan will return the Jordan normal form (not available on the ti).
Code: p,j:=jordan([[2,0,0,0],[2,2,0,0],[1,-1,2,-1],[0,1,0,2]]); p*j*inv(p); |
05-06-2016, 09:21 PM
(This post was last modified: 05-06-2016 10:51 PM by Arno K.)
Well, I did not (really) bother about the prime not being able to produce the eigenvectors, what I wanted to say is: it CRASHED using EIGENVV(M3) where M3 is one of the built-in matrices filled with the data provided above here the warning: Matrix is not diagonalizable, try.... would be a workaround.
Arno |
05-07-2016, 06:51 AM
Of course it should not crash, it's now fixed in the source code.
