Units; StdP value vs. non values
05-09-2016, 06:13 PM
StdP; non value 101.325_kPa. Correct
StdP; value 101.325. trick question or what? StdP; value 101.325E3. That is the true value!! 760mmHg |
05-09-2016, 06:46 PM
(This post was last modified: 05-09-2016 06:47 PM by Tim Wessman.)
RE: Units; StdP value vs. non values
(05-09-2016 06:13 PM)toshk Wrote: StdP; non value 101.325_kPa. Correct Actually, it has been this way even back to the 48 series. The constant lib there returns a value of 101.325 when you don't have units attached. When you are not using units, the assumption is just that in the end you interpret as kPa. I remember looking at this extensively and talking to a few physics/chemistry professors before deciding to match what was done before. I'm open to change it, but the behavior does seem to make sense in actual practice. TW Although I work for HP, the views and opinions I post here are my own. |
05-09-2016, 07:38 PM
On the historical level, I can't battle the staunch members( RPN CLINCHERS ) of this noble forum.
But "value" here is "magnitude",standard is standard. Standard pressure is 760mmHg is 101325_Pa. And not 101.325 you have to append kilos later in your calculations later. CONVERT(760_mmHg,1_Pa) |
05-09-2016, 11:17 PM
(05-09-2016 10:23 PM)informach Wrote: Hi!: The discussion is not about how to do unit conversions. It makes it very hard for people to follow discussions when you post non-topic discussions in every single thread. Could you please post only on topic things directly related to the discussion? Thank you! TW Although I work for HP, the views and opinions I post here are my own. |
05-09-2016, 11:31 PM
Hi!, Tim:
I have, the feeling, that I was wrong, in the response. It's for this reason, that I erased, what had inserted. Obviously, I wanted to clarify the units, used for years, in my profession, of oil and gas engineering and has, HP PRIME for me, is enough. Kind Regards. informach. |
