CHECK() syntax
05-19-2016, 06:32 AM
CHECK() syntax
I want to plot some data from spreadsheet in the 1var statistics app, so I used the following code:
EXPORT plot()
Statistics_1Var.D1:=C_Gain;
Statistics_1Var.D2:=C_NF;
STARTAPP("Statistics_1Var");
CHECK(1);
CHECK(2);
STARTVIEW(1,1);
But the lines CHECK(); give a syntax error in the iOS app.
Any idea why?
[/php]Steve
05-19-2016, 09:06 AM
RE: CHECK() syntax
It works fine on the real calc with 10077 firmware. Guess the iOS app will get updated at some point.
05-19-2016, 02:07 PM
RE: CHECK() syntax
Have you tried Statistics1Var.CHECK() - just in case it is attempting a different CHECK?
Stephen Lewkowicz (G1CMZ)
