[only CAS Libraries]
12-13-2013, 03:29 PM (This post was last modified: 04-17-2017 01:03 AM by compsystems.)
Library #0 HP_PrimeCASplus
http://www.hpcalc.org/details/7510
12-15-2013, 02:34 AM
RE: [only CAS Libraries]
The included "User Guide" is not in English. Nor is there any description here. Can we please have at least a brief English description of the purpose of this software and how to use it? Thanks in advance!
<0|ΙΈ|0>
-Joe-
01-28-2014, 06:55 PM
(12-15-2013 02:34 AM)Joe Horn Wrote:  The included "User Guide" is not in English. Nor is there any description here. Can we please have at least a brief English description of the purpose of this software and how to use it? Thanks in advance!
The link is dead anyway.
01-28-2014, 11:11 PM
Code
main( ):=
    CONJUGATE() := BEGIN true; END;
    SYMBOLIC() := BEGIN true; END;
    RETURN( OK );
getType( Data0 ):=
    LOCAL TypeN, TypeID, RealType, ObjStr;
    TypeID := type( Data0 );
    IFERR
        TYPE( Data0 )
    THEN
        RealType := "ERROR";
        ObjStr := "ERROR";
    ELSE
        TypeN := TYPE( Data0 );
        ObjStr := STRING( Data0 );
    CASE
        IF TypeID == DOM_FLOAT
        THEN
            RealType := "RealNumber";
        IF TypeID == DOM_INT
        THEN
            RealType := "IntegerNumber";
        IF TypeID == DOM_COMPLEX
        THEN
            IF inString( ObjStr,"(" ) >= 1
            THEN
                RealType := "CooComplexNumber";
            ELSE
                RealType := "AlgComplexNumber";
        IF TypeID == DOM_RAT
        THEN
            IF inString( ObjStr, string( i ) ) >= 1
            THEN
                RealType := "RatComplexNumber";
            ELSE
                RealType := "RationalNumber";
        IF TypeID == DOM_SYMBOLIC
        THEN
            IF inString( string( Data0 ), "=" ) >= 1
            THEN
                RealType := "Equation";
            ELSE
                RealType := "AlgExpression";
        IF TypeID == DOM_IDENT
        THEN
            RealType := "Identifier";
        IF TypeID == DOM_STRING
        THEN
            RealType := "String";
        IF TypeID == DOM_FUNC
        THEN
            RealType := "Function";
        IF TypeID == DOM_LIST
        THEN
            CASE
                IF inString( ObjStr, "poly1[" ) >= 1
                THEN
                    RealType := "PolynomialCoeff";
                IF inString( ObjStr, "set[" )>= 1
                THEN
                    RealType := "Set";
                IF inString( ObjStr, "[[" ) >= 1
                THEN
                    RealType := "Matrix";
                IF inString( ObjStr, "[" ) >= 1
                THEN
                    RealType := "Vector";
                IF inString( ObjStr, "{" ) >= 1 OR inString( ObjStr, "{[" ) >= 1
                THEN
                    RealType := "List";
                DEFAULT RealType := "Other Type LIST";
        IF TypeN == 9
        THEN
            RealType := "Unit";
        IF TypeID == 21
        THEN
            RealType := "HMS";
        IF TypeN == 1
        THEN
            CASE
                IF inString( ObjStr, "d" ) >= 1
                THEN
                    RealType := "DecNumber";
                IF inString( ObjStr, "b" ) >= 1
                THEN
                    RealType := "BinNumber";
                IF inString( ObjStr, "h" ) >= 1
                THEN
                    RealType := "HexNumber";
                IF inString( ObjStr, "o" ) >= 1
                THEN
                    RealType := "OctNumber";
                DEFAULT RealType := "Other Base";
        DEFAULT RealType := "Other";
    RETURN( RealType );
partString( Str0, StrP ):=
    LOCAL FlagBadArg;
    FlagBadArg:= "false";
    IF NOT( ( getType( Str0 ) == "String" ) AND ( NOT( Str0 == "" ) ) )
    THEN
        FlagBadArg := "true";
        IF NOT( MSGBOX( "partString: Invalid Data Type for 1 Arg", true ) )
        THEN kill;
    IF NOT( ( getType( StrP ) == "String" ) AND ( NOT( StrP == "" ) ) )
    THEN
        IF NOT( MSGBOX( "partString: Invalid Data Type for 2 Arg", true ) )
        THEN kill;
        ELSE kill;
    IF FlagBadArg == "false"
    THEN
        RETURN( convertToRealBoolean( inString( Str0, StrP ) ) );
    ELSE
        RETURN( "Invalid Data Type" );
convertToRealBoolean( Object0 ):=
    IF isBooleanDataType( Object0 ) == "true"
    THEN
        IF getType( Object0 ) == "String"
        THEN
            Object0 := expr( Object0 );
        IF Object0 <= 0
        THEN
            RETURN( "false" );
        ELSE
            RETURN( "true" );
    ELSE
        IF NOT( MSGBOX( "convertToRealBoolean: Invalid Data Type", true ) )
        THEN kill;
        ELSE kill;
isBooleanDataType( Object ):=
    LOCAL FlagBadArg, ObjectType;
    ObjectType := getType( Object );
    IF NOT( POS( { "RealNumber", "IntegerNumber", "RationalNumber", "String" }, ObjectType ) )
    THEN
    IF FlagBadArg == "true"
    THEN
        RETURN( "false" );
    ELSE
        IF ObjectType == "String"
        THEN
            ObjectType:= expr( Object );
            IF isNumber( ObjectType ) == "true"
            THEN RETURN( "true" );
            ELSE RETURN( "false" );
        ELSE
            RETURN( "true" );
isNumber( Object ):=
    LOCAL ObjectType;
    ObjectType:= getType( Object );
    IF POS( { "RealNumber", "IntegerNumber", "RationalNumber" }, ObjectType )
    THEN
        RETURN( "true" );
    ELSE
        RETURN( "false" );
isComplexNumber( Object ):=
    LOCAL ObjectType;
    IF POS( { "CooComplexNumber", "AlgComplexNumber", "RatComplexNumber" }, ObjectType )
    THEN
        RETURN( "true" );
    ELSE
        RETURN( "false" );
isEquation( Object ):=
    LOCAL FitObject;
    IFERR
        EVAL( Object );
    THEN
        FitObject := Object;
    ELSE
        FitObject :=  EVAL( Object );
    IF getType( FitObject ) == "Equation"
    THEN
        RETURN( "true" );
    ELSE
        RETURN( "false" );
eqToExpr( Eq ):=
    IF isEquation( Eq ) == "true"
    THEN
        RETURN( expr( replace( string( Eq ), "=" , "-(" ) + ")" ) );
    ELSE
        RETURN( Eq );
transpose2( Array, Test0 ):=
    LOCAL FlagBadArg;
    IF NOT( POS( { "Vector", "Matrix" }, getType( Array ) ) )
    THEN
        IF NOT( MSGBOX( "transpose2: Invalid Data Type for 1 arg", true ) )
        THEN kill;
    IF NOT( isBooleanDataType( Test0 ) == "true" )
    THEN
        IF NOT( MSGBOX( "transpose2: Invalid Data Type for 2 arg", true ) )
        THEN kill;
        ELSE kill;
    ELSE
        Test0 := convertToRealBoolean( Test0 );
    THEN
        IF Test0 == "true"
        THEN
            RETURN( TRN( Array ) );
        ELSE
            RETURN( transpose( Array ) );
    ELSE
toPoly1var( Object, Var, Test ):=
    LOCAL FlagBadArg, FitPoly, ObjectType;
    IF NOT( POS( { "AlgExpression", "Equation", "Identifier", "RealNumber", "IntegerNumber",
        "AlgComplexNumber", "RatComplexNumber", "RationalNumber", "PolynomialCoeff", "Vector" }, ObjectType ) )
    THEN
        IF NOT( MSGBOX( "toPoly1var: Invalid Data Type for 1 arg", true ) )
        THEN kill;
    IF NOT( getType( Var ) == "Identifier" )
    THEN
        IF NOT( MSGBOX( "toPoly1var: Invalid Data Type for 2 arg", true ) )
        THEN kill;
    IF NOT( isBooleanDataType( Test ) == "true" )
    THEN
        IF NOT( MSGBOX( "toPoly1var: Invalid Data Type for 3 arg", true ) )
        THEN kill;
        ELSE kill;
    ELSE
        Test := convertToRealBoolean( Test );
    THEN
        CASE
            IF ObjectType == "PolynomialCoeff"
            THEN
                IF Test == "true"
                THEN
                    RETURN( poly2symb( ObjectType, Var ) );
                ELSE
                    RETURN( ObjectType );
            IF ObjectType == "Vector"
            THEN
                FitPoly := expr( "poly1" + Object );
                IF Test == "true"
                THEN
                    RETURN( poly2symb( FitPoly, Var ) );
                ELSE
                    RETURN( FitPoly );
            IF isEquation( Object ) == "true"
            THEN
                FitPoly := eqToExpr( Object );
                IF Test == "false"
                THEN
                    RETURN( symb2poly( FitPoly, Var ) );
                ELSE
                    RETURN( FitPoly );
            DEFAULT
                IF Test == "false"
                THEN
                    RETURN( symb2poly( Object, Var ) );
                ELSE
                    RETURN( Object );
    ELSE
polyCoeffToArray( Poly ):=
    LOCAL FlagBadArg;
    IF NOT( POS( { PolynomialCoeff }, getType( Poly ) ) )
    THEN
        IF NOT( MSGBOX( "polyCoeffToArray: Invalid Data Type for 1 arg", true ) )
        THEN kill;
    THEN
        RETURN := expr( replace( string( Poly ), "poly1" , "" )  );
    ELSE
collectPolTerms( Poly, Var ):=
    LOCAL FlagBadArg;
    "AlgComplexNumber", "RationalNumber", "RatComplexNumber" }, getType( Poly ) ) )
    THEN
        IF NOT( MSGBOX( "collectPolTerms:Invalid Data Type for 1 arg", true ) )
        THEN kill;
    THEN
         IF NOT( MSGBOX( "collectPolTerms:Invalid Data Type for 2 arg", true ) )
         THEN kill;
         ELSE kill;
    THEN
        IF isEquation( Poly ) == "true"
        THEN
            Poly := toEq( eqToExpr );
        RETURN( sum( coeff( Poly, Var ) .* seq( Var^k, k, degree( Poly, Var ), 0, 1 ) ));
    ELSE
randPoly2( Pdim, Il, Sl, Var, Test ):=
    LOCAL Rp;
    Rp := randPoly( Pdim, expr( Il + ".." + Sl ) );
    RETURN( toPoly1var( Rp, Var, Test ));
polyToCoeff( Poly, Var ):=
    LOCAL PolyFnt, Out, Cnt0, Cnt1, Temp0;
    purge( Pol );
    THEN
        Poly := eqToExpr( Poly );
    expr( Pol(Var)+":="+string( Poly ) );
    Out := MAKELIST( 0, Cnt1, degree( Poly ), 0, 1 );
    Cnt0:=0;
    WHILE Pol(Var) <> 0 DO
        Temp0 := Pol(Var) / (Cnt0!) ;
        Out[ Cnt0 ] := ( Temp0 | Var=0 );
        Cnt0 := Cnt0 + 1;
        Pol(Var) := diff( Pol(Var), Var);
    Out := expr( "poly1[" + string( REVERSE(Out) ) + "]");
    RETURN( Out );
