Bugs with "Copy" soft key in CAS mode
07-04-2016, 01:34 PM
I've noticed two bugs with the "Copy" soft-key in CAS mode: - when i try to copy a command that contains a number in scientific notation, the result is this: Sometimes the command is still accepted, sometimes no. - when i try to copy a command that contains a *(i don't know how it's called)* this is the result: This is quite annoying, especially with large formulas. Is there a way to solve this? |
07-05-2016, 05:07 AM
RE: Bugs with "Copy" soft key in CAS mode
The first one seems to work on the latest firmware. Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
07-07-2016, 10:25 PM
What do you mean? You can't reproduce it or the command is still accepted? On which firmware?
