HP 75 - Quick Reference Sheet
07-11-2016, 01:00 PM (This post was last modified: 12-07-2016 09:25 AM by Martin Hepperle.)
jumping between BASIC machines like the Series 70, Series 80 and, Series 9000 can be confusing due to the sometimes subtle variations in functions and syntax. As I could not find a HP-75 QRG I created a QRS for my personal use.
See attachment.
Maybe it is also of interest for some of you. Printed two-sided on paper or thin cardboard, cut and folded into a Z-shape produces a handy reference card.
There is still some free estate which could be filled with other useful information.
I thought about adding syntax for one or two key LEX files like HPILCMDS and RIOWIO. Any other ideas?
Martin
[Edit: 12-JUL-2016: 2 typos in PDF corrected]
[Edit: 25-JUL-2016: syntax for HPILCMD LEX file added]
[Edit: 6-OCT-2016: document outsourced to
http://www.mh-aerotools.de/hp/documents/...erence.pdf]
[Edit: 6-DEC-2016: argument type error for NUM() corrected, HPILCMD parameters detailed]
07-11-2016, 01:47 PM
RE: HP 75 - Quick Reference Sheet
(07-11-2016 01:00 PM)Martin Hepperle Wrote:  There is still some free estate which could be filled with other useful information.
Very nice Martin, thanks for sharing!!
As a mostly 71B BASIC user, I find the 75C/D and 80 series BASICs very foreign, so this QRG is very useful. I suggest also adding the IO ROM, since most serious 75 users probably use this ROM, as it's nearly required to do anything useful that involves serious HP-IL use.
07-11-2016, 01:51 PM
Thanks for sharing this nice QRG!
Maybe a few commands from the I/O ROM may fit into the free space ...
07-11-2016, 03:29 PM
(07-11-2016 01:51 PM)Jurgen Keller Wrote:  Thanks for sharing this nice QRG!
Ah yes, the I/O-ROM ... if I only had one ...
I will check how much space a complete listing of the I/O ROM commands would take. I might remove the upper half of the character table, instead.
Martin
12-02-2016, 11:48 AM
Hi Jurgen
Thank you very much for the QRG. I have tried to download it but am getting a 404 Not Found message... wonder if it would be possible for you to upload it?
Thank you!
Goncal
12-02-2016, 03:11 PM
(12-02-2016 11:48 AM)goncal Wrote:  Thank you very much for the QRG. I have tried to download it but am getting a 404 Not Found message... wonder if it would be possible for you to upload it?
Hi Goncal,
Jürgen is not responsible for this problem ... I had changed the file name ... the link above has been updated and should work now.
Martin
12-03-2016, 08:28 AM
Thanks very much Martin & I like the Roo on the front page :-).
Cheers,
Michael
